P1000 True Tire Sizes
Russ989
Russ989
22,645
147,291
How do you like them? I’m thinking about getting some 35’s!!
So far, so good. They clean out well in the mud and have pretty good traction on rocks. With enough throttle they will dig down and try to grab something to move you forward. I was climbing a short bank in 2wd in February or March, super sloppy and slick and they removed roughly 4-5” of mixed slop to find the bottom. I’m still washing that damn mud out from under the machine. They seem to have decent traction in reverse as well.
  • Haha
Reactions: JTW
196,548
kind of makes the measurements moot if they're unloaded.
A 28" on a P1 at 7 psi compared to the same tire at 10 psi on a P5 would no doubt result in different measurements. Unloaded is the only accurate measurement to be had, everything else is moot and probably why the Faceturd measurements are all over the place.
BigOL3
BigOL3
2,997
8,921
Be cool to get some more validated info on some of the lesser known/newer 27"-32" tires. @Russ989 what do your K9's run? @BigOL3 @JTW what about the 28 and 30 Berserkers? @Bad_bowtie give us a size on the 30" Terra-hooks
According to my post when new last year, 5/19 ....... Aired up to 20#, 29 1/8"!!!!! ...... not installed on P1K5 at that time.
Installed on P1K5 with 20# measured 28.75" ........ At 10# 28.25" tall ..... With pressure at 10# each, all tires sit at full 28"
I have since lowered the pressure to 8#, IIRC they measured less than 28", seems about 27.5". I will try to check them later today.
Just double checked, using a 2' level ....... 2 rear tires @ 8#s are 27.25", RF tire @ 8# is 27.75", LF tire, the one that appeared to be FLAT when entering V Notch at Tackett Creek, had only 6PSI is 27.5".
Reactions: Adam490
63,075
Thanks O, I updated
Reactions: BigOL3
Isaiah
Isaiah
2,191
6,964
Altamont TN
Anyone know the true size of 30in or 32in system 3 xt300?
63,075
Probably pretty true to size based off the XTR350's that @DDDonkey posted about earlier in this thread. I think @Tramguage1 just ordered some new System 3 tires as well for his Talon so he can probably get us a measurement on those to add to the OG post. I'm going to update it with the size for the 30" Rockzillas as well.
Isaiah
Isaiah
2,191
6,964
Altamont TN
Alright thanks!
63,075
@JTW how do the K9 35's measure up? @Plumber32 @Bad_bowtie what about the Terrahooks?
Reactions: Isaiah
Tramguage1
Tramguage1
Texan
7,608
31,549
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
Hopinv to get them this weekend. Not sure but hopping too. Will be more than happy to get a true size.
Reactions: Isaiah and Adam490
Bad_bowtie
Bad_bowtie
Huge member
2,571
15,898
East Tennessee
I've ran my 30" TerraHooks at max pressure alot to be DOT compliant, as we can ride the highway here. They seem to have stretched to be over 30" actual measurement. I remember @Plumber32 saying mine were noticeably larger than his same size Terrhooks. This pic was taken back in May, but haven't measured recently.
20200522 193712
63,075
I've ran my 30" TerraHooks at max pressure alot to be DOT compliant, as we can ride the highway here. They seem to have stretched to be over 30" actual measurement. I remember @Plumber32 saying mine were noticeably larger than his same size Terrhooks. This pic was taken back in May, but haven't measured recently. View attachment 244158
Damn, you've got to be hitting the front bumper under full compression huh? Those are bigger than @joeymt33 32" Terrabites lol
TripleB
TripleB
21,111
183,546
Caryville, Tennessee
You're huge!
63,075
The 35’ K9’s were 33 3/4 on the machine at 10lbs.. also, I don’t really care for the tire. I’m switching to zillas or berzerkers
Hurry up and sell them while they are the "hot" thing to have.
NicholsonYes
1609385037930
  • Haha
Reactions: TripleB and Mudwing
Bad_bowtie
Bad_bowtie
Huge member
2,571
15,898
East Tennessee
Never noticed hitting the bumper but if the wheels are turned with much articulation, the mud busters are catching hell. Those things are tough!
  • Haha
Reactions: Mudwing and Adam490
