![Bulldawg Bill](/data/avatars/m/58/58592.jpg?1722450254)
Hoping someone can help or has encountered this problem before. I have a universal turn signal kit, a POS the dealer was supposed to install and never got it done, so I decided to install myself. Should have eaten the cost and bought the one from the club store, but hindsight is 20/20.
There is no brand name, but when I did a reverse image search on the instructions it pulled up the universal kit from Rough Country. It doesn't have their branding, but is otherwise identical. Here's the problem. After running all the wires, drilling holes, etc., I got to the testing phase and only the rear signals flashed, front ones appeared dead. Thinking it was a wiring issue, I pulled the rear wires back out and connected them to the front signals. Both worked, establishing that the problem is not in the wiring to front signals. I next put the rear LEDs into the front signal wires, and they worked, but the front signals stopped working. It appears all the wires work, all the LEDS work, but only two will work at once. I also note that the two that work stay lit when no signal to flash is being sent, I expected them all to be off unless a turn or hazard signal to blink was being sent.
I've triple checked the wiring, I cannot find anything I did wrong, and the horn that is part of the kit works properly. I'm guessing something is wrong in the box that is the brains of the system, but before I scrap it and buy a new one I thought I'd see if anyone can help. It is solidly grounded.
Any help would be greatly appreciated!
