Tusk Kevlar Terrabite Tire Review! - 30x10x14
66,869
Upload 2019 1 28 19 8 1
Finally got around to ordering a new set of tires for my Honda Pioneer 1000. After considering a few choices I decided to go with the Tusk Kevlar Terrabite tires in size 30x10x14.
Check them out here --> Tusk Kevlar Terrabite Tire
A427528f4c429da8bf91da04eb0d9e77
My Setup:
  • Honda Pioneer 1000-5
  • Tusk Terrabite Kevlars 30x10x14.
  • Factory Rims.
  • SuperATV Arms on the front only.
  • 1" spacers on the front. 1.5" spacers on the rear.
  • Walker Evans Shocks.
  • No lift or gear reduction.
32d4b36914144157cf39c93b4595dcfdC3d27fdf35a0dc62b021d8497a9553d23e646d9cedf585557d59a5d204c501d5
Advertised Tire Specs for 30x10x14
  • 8 Ply Rated
  • 3/4 inch tread depth
  • 34.9 pounds
  • DOT Rated
Actual Tire Measurements
@8 psi - 28.75 inches tall.
@14 psi - 29 inches tall.
@30 psi - 29.5 inches tall.
Dc4feb85dfd706379515ced2ff0575d0 885984eff54a5d1227d27ad49ce41861 Caf55ed47667ecf051987913e12c3df8 Cc5a2cdbf83c07efd101b6cc0bd2e387
(add wheel well clearance shots soon)
Actual Tread Depth
The thread measures right at 3/4 an inch.
9348dd1a0b52db85ba46149b40832686
Why I chose the NEW Tusk Kevlar Terrabite Tire!
Mostly because I am tired of sidewall damage due to pinch flats. I hope this kevlar tire can hold up at a lower PSI at the faster speed I tend to run. I previously ran a set of Roctaine XS's and put 3 pinches in those with 1 tire completely needing a replacement. Factory BigHorns didn't last my initial weekend run before both fronts had sidewall pinches.
Upload 2019 1 28 19 7 23
Check out the new Tusk Kevlar Terrabite here --> Tusk Kevlar Terrabite Tire
Ragnar406
Ragnar406
The Great Bald One
4,449
17,027
Bella Vista, AR
My Setup:
  • Factory Rims.
View attachment 104809View attachment 104807View attachment 104808
  • 8 Ply Rated
  • 34.9 pounds
  • DOT Rated
View attachment 104810 View attachment 104811 View attachment 104812 View attachment 104814
Actual Tread Depth
By gosh if that solves your pinch flat problem I may be following you.. I can pinch flat the heck out of some tires.. just got to where I run more pressure in them but still always a little worried.
Looking forward to your review and because I have seen you ride I know they will be tested well
66,869
Out of curiosity, what psi are you running? And what kind of terrain to cause all those flats? Hope the new ones work out for you.
I have tried many PSI levels. Most pinches come with lower pressures under 10lb. I started sticking to the specs of 14 and seem to have slowed the pinches down but I still have a few. I usually run fast speeds on rocky trails. That's what will do it. Especially if you are under 14 PSI.
HOW MUCH?
Here - https://bit.ly/2FlUB3A
Reactions: sharp
69,050
Here - Tusk Kevlar Terrabite Tire
I thought you would get a couple more seasons out of the rocktanes! Still had plenty of tread :D
208,726
I busted two stock fronts, 3 inch rips, in both, a 1 inch rip in a EFX 8 ply. Went to 30 x 10 x 14 ITP Black Waters, no flats so far. I ride slower than some and faster than most, love the rocks. They do leak around the bead locks slowly. I'm running up graded A arms and shocks. These Pioneer's are great machines but they are no Talon and you can tear them up without having a wreck.
G
gweedo
6
Odaho
My Setup:
  • Factory Rims.
  • 8 Ply Rated
  • 34.9 pounds
  • DOT Rated
Actual Tread Depth
I have the 16 1000-5 delux, I would like to get more ground clearance and new tires. i like the Tusk Kevlar, however, I looked up the super ATV arms you mentioned and it says the max tire size is 28" are you having any issues, like rubbing etc. Thnx,
Reactions: sharp
G
gweedo
6
Odaho
208,726
Same set up no issues! With 30 inch ITP's
Reactions: CumminsPusher
G
gweedo
6
Odaho
Thnx for the info. I am newer to the site. I haven't had much time to make some good changes, but that is changing soon. It sounds like the SATV arms are a good way to go. One issue I will have is putting into my cargo trailer, I can do it now if I lower the tire pressure and sit my on the rear, once I'm inside I'm good. My son in-law suggested I look for some super low profile tire to switch out in order to trailer it. has anyone done this or found tires that would work? or have any other suggestion beside buying another trailer LOL. thnx
Reactions: sharp
Eltobgi
Eltobgi
4,599
15,186
North Dakota
Chop the cage:cool:
77TOY
77TOY
America
Is anybody running Pro Armor Crawler XG 30x10x14?
I have the Highlifter A arms that move the axle forward. Still have factory rims 14 x6.5 in front 14x8 in rear. Everything else is stock. Will I need lift or spacer to percent rubbing?
Reactions: sharp and Bones
DFABane
DFABane
21
34
Ok... I'm a newb.... So what are pinches and should I be concerned about them with my P-500 and stock tires at 10psi???? I trail ride but not on trails that are terribly rough...
77TOY
77TOY
America
“Pinches” or “pinch flats” occur when the tire gets pinched between the wheel rim and a hard object (rock, log etc). They usually occur in the tire sidewall (not easily trail repaired). The lower the pressure the softer the tire, the faster you drive the higher the risk. Slow speed driving over moderate terrain with soft tires are not at a high risk. Softer tires make for a comfortable ride, but leave you volnerable in high speed rocky terrain.
