Bradley-Thornton
Will add trail review here soon!
I can fit 32s on my ride for the rocks and trails would 32s be to big. Would run spacers but thinking about center of gravity on my 1000-5
If you don't have the gear reduction 32" will be to big in my opinion.I can fit 32s on my ride for the rocks and trails would 32s be to big. Would run spacers but thinking about center of gravity on my 1000-5
Those outbacks will probably do great. I believe there were several machines with them last year and they did great. Wait wasn't that you that went with us over the widowmaker ect?Have it got 32 outbacks for mud riding need something for Royal Blue?
I just put 30X10X14 Tusk Terrabyte Kevlars on my 2018 P1000-5 LE with 1" spacers in back. No lift and no new A arms. At 10 lbs. the fronts would rub some on full lock turns at 8 lbs. not so much. I expeirenced some lugging of the motor on super steep hills with rock ledges, not a real problem, just needed a little more throttle and I was up and over. The traction difference over stock was nothing short of amazing! Went up two four foot slippery waterfalls with no problems. Climbing up steep and rock infested trails at Turner Falls in Oklahoma was also no problem. Super tough sidewalls never failed me, even though I hit some sharp rock pretty hard, no pinches. I can't recommend the tires enough, pricey, but well worth it.No, but I'm hoping to go this year have a trip planned June 5th-11th regardless.
If I haven't welcomed you, WELCOME! Club rule 19 clearly states with out pictures it didn't happen HA! We like pictures!I just put 30X10X14 Tusk Terrabyte Kevlars on my 2018 P1000-5 LE with 1" spacers in back. No lift and no new A arms. At 10 lbs. the fronts would rub some on full lock turns at 8 lbs. not so much. I expeirenced some lugging of the motor on super steep hills with rock ledges, not a real problem, just needed a little more throttle and I was up and over. The traction difference over stock was nothing short of amazing! Went up two four foot slippery waterfalls with no problems. Climbing up steep and rock infested trails at Turner Falls in Oklahoma was also no problem. Super tough sidewalls never failed me, even though I hit some sharp rock pretty hard, no pinches. I can't recommend the tires enough, pricey, but well worth it.
They seem to be a good tire from what I’ve seen. My 700-4 had Roctane XDs and they were tough as nails, I ran 6-9psi most of the time with them. I’m going to go 28x10-14 on all four and trying to zero in on what I want to order.Terribates have been a good tire for me the last 2 yrs.
So you guys that have the terrabites, do they perform pretty well? Would you buy them again over other tires like the Roctane XD or the Maxxis Carnivore?
Why 12” wheels? Is it more sidewall flex? I’ve always figured 14” wheels and tires were better because they had a shorter sidewall. Just curious on your thoughts since you’ve been doing this longer than I have.I like my berserkers a lot better than the terrabites... 28” berserkers on 12” wheels would be my suggestion!
Yes.. the ride will be much better. You’ll get the same sidewall I have with 14’s and 30’s.. but will lose a lot of weightWhy 12” wheels? Is it more sidewall flex? I’ve always figured 14” wheels and tires were better because they had a shorter sidewall. Just curious on your thoughts since you’ve been doing this longer than I have.
Gotcha, thank you for clarifying.Yes.. the ride will be much better. You’ll get the same sidewall I have with 14’s and 30’s.. but will lose a lot of weight
