P1000 Tusk terrabite ?
gullyjumper
gullyjumper
950
2,413
cookeville tn
Ive been looking at Tusk terrabite tires in size 28x10x14 for my stock 2016 pioneer 1000-3. I may be using the stock rims ( not sure ). My question is will I have any problems like rubbing or anything else ? Anyone with these tires ? I don't have a lift or want one. Thanks
X4Dice
X4Dice
87
130
USA
I have the same yr and model. I have the tusk terrabite 28x10x14 all the way around with ITP Hurricane wheels with a 14X 7 5.0+ 2.0.from Rocky Mountain ATV. They rub little bit if I turn it all the way. I really like the tires a lot.
Yep.. on stock deluxe rims but I do have a HL lift.. shouldn’t be a problem at all for ya on stock wheels.
774FAC8A 678F 4585 86DA C352CD04A024
themightymet
themightymet
37
74
Northeast Ohio
I have the terabites on 14" STI wheels. I love them. I just had the machine at Hatfield earlier this week. We put 100 on in the rain on Monday and another 70 in dry conditions on Tuesday. They performed awesome! I have zero tire rub and the handling is great. If you plan to use them I. The mud often then you should look into a different tire. I feel like these would be ok in a little mud but anything deep or with a lot of clay you will be in trouble.
Sent from my iPhone using Tapatalk ProD91e8c009b6cd601a17e5c0687beb4ed
drfubar
drfubar
TheDonFather
5,889
19,242
Mary's Ridge (Dayton Mtn), TN
Your stock rims are probably 12 inch you will have to buy 4 more if you are going to use 28x10x14's. I have them on mine right now and I like them but they are not the 28" ITP Evos by no means. I can swap back and forth depending on the area I'm going to ride.
Reactions: Dasmoeturhead
gullyjumper
gullyjumper
950
2,413
cookeville tn
Thanks for the pictures that does look good. I do have the 14" wheels with bighorns now so I was concerned about rubbing.
urbancoyboyja
urbancoyboyja
Buckle Up, I Want To Try Something...
182
389
WV, USA
Anybody know if you can get 28" terrabites for the 12" tims?
txsurfer
txsurfer
496
990
Santa Fe , TX
Maybe a stupid question - if I add an 1" in tire size 27 to 28 - I should only add about .5" to overall height correct? I have some clearance constraints with my toy-hauler is why I ask.
Plongson
Plongson
271
1,027
Southern Utah
They say that some tires actually have a radius/diameter inconstant with the number on the sidewall. Look at some comparison photos posted here and you'll see what I mean.
Yes.. the issue is not all tires run true to size. So when you switch from a 27” stock tire to a 28” terrabite that runs pretty true to size.. you might gain an inch or two due to actual size difference. Obviously, the gain is split in half.
gullyjumper
gullyjumper
950
2,413
cookeville tn
Just got around to ording a set of the tusk Terrabite tires in 28x10x14 . Hope I like them !
