I could feel a clunk sometimes on the drivers side front end , felt like a loose shock mount, but could never find it. Yesterday i had it up on the forklift changing tires and was giving each tire a shake to see if i had any bearing play and the front drivers side had alot of movement. I found the upper a arm was moving around like the bushings had gone out. I took it apart and found the bushing was still ok but there is a sleeve/collar that goes thru the bushing and the bolt thru it wasnt installed at factory. I just had the bolt going thru the nylon bushing which left alot of space for the a arm to move around on. part # 9 on the diagram ( if i can get it loaded up on here )
