P500 Upward and Outward (27s on 12" 4+3)
futzin
futzin
4,131
30,689
Kentucky
Pretty much decided to give the little P5 some better height; and since my head-bangin' days are mostly over: some width.
Under consideration: Kenda Bear Claw HTR, undecided on wheels
27x9x12 for front
27x11x12 for rear
4+3 rims front and rear, no spacers
Can anyone guesstify what my width might be? Any other thoughts are welcome. I feel like I wouldn't mind if the rear was wider than the front . . . don't know why . . . maybe better in ruts?
Thanks . . .
Reactions: Isaiah
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
If not in western KY where its flat i would go out as well. I learned the hard way. Put 1.5" spacers on back the next week. 26" on 12" 4:3 wheels
IMG 2866
futzin
futzin
4,131
30,689
Kentucky
Yikes, that stinks. You went over on 26s on 4/3s? What width tires? What are your front and rear widths now? Wider in the back? Like it?
Will be in plenty of rocky, hilly, off camber situations and whatever mud I can't avoid. (Daniel Boone Nat'l Forest area)
I hadn't really planned on 4+3s and spacers both.
Reactions: Isaiah
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
26x11x12 in rear 26x10x12 in front. I will have to measure again but i believe i am now 52" wide with 3" of spacer. I am in the Ashland KY area and it was spooky on steep side hills before the spacers. The front and rear are pretty close to same width with rear spacers. The bad part was i had not added a winch yet so i had a mile and half walk to get my rancher with winch to pull back on all 4's.
Reactions: Isaiah and futzin
futzin
futzin
4,131
30,689
Kentucky
Looks like the weather was good, at least.
I would have thought with 4+3s and spacers that you would be wider.
I tried to find factory wheel offset numbers; no luck yet.
Splorin
305
863
Maine
Stock, FR 4.5- 1.5= 1.5 neg off set. Rr4.5- 3.0= .75 neg off set. or so ish...
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
I may be wider i need to measure again, all i know its much more stable with the spacers.
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
My wheels are STI HD Alloy telfon coated 5-2 offset and not 4-3 like i thought. Found the paperwork.
Newbed1
70Bones
70Bones
888
3,779
New Brunswick Canada
I have 1" spacers, and just bought a 4-3 rims off a Yamaha, so I'll be out 2 inches each side, should be 54" wide when I git er done.
futzin
futzin
4,131
30,689
Kentucky
Thanks guys.
I'm thinking ITP 4+3 steelies, no spacers. Dennis Kirk seems to have the best price on the tires and wheels that I want, but only have 1 of 4 tires in stock. Wonder how long for backorder tires?
@KYhillbilly, your rig looks much better rubber side down!
Reactions: Isaiah
futzin
futzin
4,131
30,689
Kentucky
20200315 183915
One tire received, no telling when I'll get the others. Can't get tires, can't get Torq Locker, don't want to install winch before locker. But I got the power steering on it, boy howdy!
futzin
futzin
4,131
30,689
Kentucky
Have now finished the torq locker install, winch install, and mounted the new tires and wheels. Unfortunately, I can't post pics from my phone like I've been doing, for some reason. Not much fun without pics, but I'll say, Damn what a difference going from 24s to 27s, just on looks alone. Can't wait to hit the woods!
Slayer
Slayer
76
96
Louisiana
@futzin please let me know how this works out for you....this is the exact setup I am looking at. Did you go 4+3 with no spacers? Front and rear width equal?Price?
Reactions: Isaiah
futzin
futzin
4,131
30,689
Kentucky
I did go with 4+3 steelies with no spacers. Looks fantastic. Tape measure says front and rear both 53.5 wide but I swear the front looks a scosh wider.
Haven't taken a trail ride yet but will today. I just installed Torq Locker also.
So far this set up with power steering and no anti sway bar feels great. I think I was around $650 for wheels and tires. I've slept since then so I forget!
I can see me installing 1" spacers in rear and adding the Mudbusters package. Not sure though. Would then have a 55" wide machine at the rear plastics. Would prefer a rear fender mud flare instead.
906UP
906UP
14,241
134,968
da Yoop
Since the wheel offsets on the stock wheels are not equal front to back it will require a 1" spacer on the rears to equal out the front/rear when running the same wheel/offset all the way around.
Reactions: trigger and Isaiah
Sp1992
Sp1992
Ontario
28x10-12 cst wild thangs on itp steel wheels. 4+3 offset. About 1" narrower on the rear.
20200408 182152 20200402 184727
futzin
futzin
4,131
30,689
Kentucky
I'm running 9s front, 11s rear
futzin
futzin
4,131
30,689
Kentucky
So you have 4+3's, 9's in front and 11's in rear and you want to add spacers? Why, do you find it tippy?
I only said I was considering it. I just don't want the front wider than the rear (and it isn't).
20200415 123657
Run it. See how ya like it before spacin it.
Took it out for an extended ride yesterday. Love it! Didn't get into much off camber stuff, but not planning on any spacers.
Doing so many mods essentially at once transformed the machine. Much much smoother and way more capable.
Bought it last year, put 200 miles on it. Did some bolt on stuff, nothing to effect capability. Over the winter:
1. Removed anti sway bar
2. Installed Power steering
3. Installed Torq Locker.
4. Installed 27" tires on 12" 4+3 wheels
20200414 162735
20200413 203618
I know not everyone can do these things all at once, but damn it was so worth it! Still surprised the Mrs didn't cut me off.
20200415 124519
I'm now at 53.5" wide front and rear and the difference in the woods is noticeable for sure. Before, I was just a little wider than a 4 wheeler. Now, I feel like I'm just a little narrower than a standard SxS. Still, for the significant improvements in ride quality and capability, I have zero regrets. HUGE smile on my face after going up Rubble Hill (as I call it). The power steering is fantastic, and really helps navigating tight spaces quicker and more accurately. I did high center it once; winch works fine! Also used the winch on a large log. I had a really good day! Rolling around in the cool weather with roof, windshield and rear panel was pleasant.
20200415 123451
Coming back on topic:
The tires are definitely aggressive, but I'm very happy with them. But they are NOT turf friendly, and people will be able to track you on most any surface! Great for gravel, dirt, mud and rocks. Not the best on pavement, not surprisingly. Not bad though. They do throw some mud, but unless the Mrs. objects to how much gets on her, I'll not do Mudbusters at this time. I would like to add center caps to the wheels though if I can. Not crazy about the white showing.
Sorry about the rambling, just wanted to get my observations down someplace.
Big thanks again to you guys for the help. I'm sure I'll do a few more things to it, but for now I'm excited about my Critter!
20200415 195906
