Using Hondas Accessory Fuse Box for non Honda Accessories
rellison110
45
7
For those of you that either have or plan to install Hondas accessory switch panel and fuse box, there is an issue that has frustrated me to no end. The switches and plug in connectors are vendor are and proprietary to Honda. Fortunately for any Pioneer owners wanting to install this, I have located and now installed non Honda items using their accessory fuse box and switch panel.
The connectors and associated pins that go inside the connector are available from Mouser Electronics.com and the part numbers are as follows:
Two pin is 538-50-84-1020
Three pin is 538-50-84-1030
Four pin is 538-50-84-1040
The pins is 538-02-08-1002
I have only used the two pin so far, as that was all I need so far. I soldered my connectors.
I purchased switches from OTRATTW.com and they are Carling Tecnologies V series. I chose the Contura two which have two illumination functions. They illuminate with a bar at the bottom of the switch when the head lights are on, and then the designated symbol on the switch lights up when the accessory is in use.
You will need to modify the Honda connectors that plug into the switch panel per Carlings switch wiring diagram. I wired directly into the head light switch wire for the lower illumination function. It is a black and white wire that is under the hood, by the wheel well on the drivers side, and is a two pin connector that if you pull it apart, will disconnect power to the head lights, that will tell you that you have the right wire.
67,170
Re: Using Hondas Accessory Fuse Box for non Honda Accessorie
This is great. We have been looking for those plugs so you can connect non Honda lights to the honda accessory box.
F
farmer700
80
I been reading about people who bought the accessory box and wanted to install a aftermarket light.
Looks like you need to buy the metal inserts also.
rellison110
45
7
The last number designation is for the pins
Elkhunter
Elkhunter
345
453
Minnesota
Where can I find a carling non illuminated switch? I don't want to splice into my headlight switch. I just want a switch that will go into my Honda switch plate and plug in to one of the accessory harness plugs for a backup light. Did a search for the same switch that came with my Honda lights Carling V151-132R but with no results.
67,170
Elk,
You do not have to wire up the lights.
And they do sell non lighted switches too.
Order this one - http://www.otrattw.com/proddetail.php?p ... -00000-000
And you will need the rocker, say this one - http://www.otrattw.com/proddetail.php?prod=VVPZC77-58B (order rocker only)
Reactions: Deluxe700
Elkhunter
Elkhunter
345
453
Minnesota
Thanks Honda SxS! I was confused on what to order.
W
wataboy
72
107
SoGA
Has anyone tried to run the switches of the oem acc box to the center "warning" panel? Is the harness long enough? Thanks
STRATOSMICRO
STRATOSMICRO
37
22
49221
  2. Other Brand
This kit is available for the P1K and the P700 for the DIY:
KIT#26 HONDA PIONEER 700, D.I.Y. , SWITCH & CONNECTOR KIT FOR 0SA30-HL3-100 | eBay
KIT#14, HONDA PIONEER 1000 3P/5P, D.I.Y. SWITCH & CONNECTOR KIT, 0SA30-HL4-100 | eBay
P700 diy
99ridered
99ridered
10
9
Ohio
Will those part numbers work for the 1000 also?
W
wyowrangler
wyoming
can you tell me what I need to plug into the fuse panel? i have just figured out that I do not want to go with honda high priced accessories always. thanks
