Honda1000-5
Well the title sort of says it all---are vent tube extensions necessary? Anybody had problems without extensions or had problems from doing the extensions? Thanks.
Thanks, ordered a kit this am.Do the two fuel and sub trans at least. I have a kit if you want to do them all or I hook you up with just the two. To do them all takes about a hour. Nothing has to be removed. Simple install. Shoot me a email if a can help. [email protected]
Ship out tommorow 2-3 day shipping thanksThanks, ordered a kit this am.
I have a 2018 pioneer 1000 3 seater and would like to get a kit for the vent issue from youDo the two fuel and sub trans at least. I have a kit if you want to do them all or I hook you up with just the two. To do them all takes about a hour. Nothing has to be removed. Simple install. Shoot me a email if a can help. [email protected]
What is in this kit? Is it just fuel lines?
Every thing needed to extend the 6 factory vents. Tubing , fitting, tie wraps.What is in this kit? Is it just fuel lines?
The differential vents to the frame.Hey Y'all, I'm a new 1000-3 owner and just got my vent extension kit from Ross. I'll preface this with "I'm no mechanic". Following the included instructions for the fuel vent, it says to pull the tube out of the frame. If I'm looking at the correct hose (attached to the white plug on top of the tank?), I see it connects to a box in the center of the seat, not into the frame. Am I looking at the right hose?
Mine is a 2018 1000-5. It was stuck into the frame on the backside of the seat.Hey Y'all, I'm a new 1000-3 owner and just got my vent extension kit from Ross. I'll preface this with "I'm no mechanic". Following the included instructions for the fuel vent, it says to pull the tube out of the frame. If I'm looking at the correct hose (attached to the white plug on top of the tank?), I see it connects to a box in the center of the seat, not into the frame. Am I looking at the right hose?
Is Ross, bayouownbeer? If so he has pictures on Facebook.Hey Y'all, I'm a new 1000-3 owner and just got my vent extension kit from Ross. I'll preface this with "I'm no mechanic". Following the included instructions for the fuel vent, it says to pull the tube out of the frame. If I'm looking at the correct hose (attached to the white plug on top of the tank?), I see it connects to a box in the center of the seat, not into the frame. Am I looking at the right hose?
You are in California, with a California model.Ya, it's from Ross and I have his instructions. I'm just not seeing what he is describing. I've included 2 photo's (hopefully) showing the line leading away from the tank and where that hose goes into the box.
View attachment 116521 View attachment 116522
