Multi Want to start a discussion about everyone's home shop and shop projects.
ToyMan
ToyMan
61
162
NV
IMG 3249
My shop/RV bay. The building is 40ft deep, there is a home machine shop behind the auto bay.
IMG 3248
RV bay, Looking for a spare wheel/tire to mount on the carrier.
IMG 3246
Panorama of the ‘dirty’ part of the shop, all welding, cutting, grinding…messy stuff is done there. I pull my Baby (Cummins) out when I get grinding/plasma cutting/welding savage.
IMG 3244
Panorama of the back room. No grinding or abrasives allowed. A little Rong Fu mill/w custom base, all DRO’d, HF air over press, Jet 12” lathe, all DRO’d, 1/2 bath and washtub out of picture to the left and most importantly
a fridge packed with 29 degree cold IPA.
IMG 3254
Panoramic of the house garage….I like 4Runners…..
DRZRon1
DRZRon1
1,445
4,418
PA
awesome !!!!!
smart
Reactions: Rayger143
MI-Trailblazer
MI-Trailblazer
305
1,508
Parma, MI
I just found this thread yesterday and after reading through it all, you guys have not only prompted me to post up pictures of my shop, but also have motivated me to try and start getting back to finishing the inside and organizing things better!
So to start, here is the build of my shop:
1  barn floor cement as of 10 18 06
We start with the 40' x 80' - 6" re-enforced cement pad with 22 1-ft dia. 48" deep pilons with 3/4" J-bolts in them. My only regret was that the guy that poured the cement and finished it asked me if I wanted him to put the pex tubes in it? I said no (dumb ass).
2  Barn site as of 6 24 07
The J-bolts then got brackets attached to them, then the post/truss assembly you see in this pic. is assembled laying on the cement pad with mating brackets attached to the bottom of the posts. These brackets then act as a hinge and you stand-up the post truss assembly, I did so using cables, snatch blocks and my tractor.
3  looking from west end of barn  7 10 07
Once you get 2 of the post / truss assemblies up you attach the purlins and girts, then build and stand up the next pole/ truss assembly and continue on till you get to the other end.
4  resized   Barn as of 7 16 07
5  barn roof as of 10 13 07
Once you had the structure up the roof was next. I was talked into covering the structure with the foil - bubble wrap for "cheap" insulation to start off with. I also at this time could not afford a metal roof (metal prices crazy in 2007) so with shingles I put the bubble/foil insulation down first to the purlins, then put 2x4's over the bubble/foil, then attached the roof sheeting to the 2x4's creating my air gap for the soffit and ridge vents. Also the bubble wrap does actually work - the inside of the barn stays 10 to 15 degrees cooler than the outside temp. in the summer and 10 - 15 warmer in the winter.
6  Southwest corner as of 11 18 07
Once the roof was done, time for the end walls and steel siding.
7  SE corner of barn 1 9 08
8  barn as of 1 9 08
So I cannot take credit for this entire construction project. I made it up to having 3/4 of the roof done, snow was about to fly and I was only working on it on weekends, so I hired the crew that did my house addition to finish the roof and do the end walls and siding. As well as I have a bad track record with hanging overhead doors, so I hired that out as well.
9  inside barn SE corner as of 5 28 09
On the inside there is a 40'x40' loft over the back half. In the picture above you can see the start of the chaotic mess in there was the "rushed" necessity to get stuff out of the weather and out of the yard. Over time I added some of the electric, insulated one corner so I could some-what set up a work area and not need to move everything again to finish things.
10  inside barn SW corner as of 5 28 09
For the walls I was just putting up 2x6's to match the window opening framing, put up roll fiberglass insulation, then hanging drywall - no tape no mud then primer and paint.
11  Loft progress 2014
This is a shot of the loft floor construction. All the floor joists are in now. I have a couple of the wedge plate boards to cut and install between the bottom of the joists and the bottom lip of the I-beam. Then start gluing and screwing the floor sheeting down. Still a lot of work to go to finish it. You have me now planning when I can get started on it again!
MI-Trailblazer
MI-Trailblazer
305
1,508
Parma, MI
Since my post above was getting huge, I'll add some of my "why did you do thats?" in this one.
I've always wanted a pole barn to work out of, but being an old barn lover, I did not want to put up a pole barn that looked like every other pole barn. So after doing a lot of figuring I settled on the 40' x 80' size with the front half open for the workshop, then the back half lofted, with vehicle/toy storage under and parts and everything else storage on the loft.
I wanted the gambrel roof for 2 reasons: 1) the look, 2) I wanted to clear-span it and put a tall over-head door in the end and keep the side walls shorter. My first hurtle for these plans was the clear-span 40' trusses. I found that I could go with scissor trusses in the front half then attic trusses on the back half. Only this was going to cost about $28k just in trusses.
My next delema was I went an bought an RV. Well, building a barn, not going to leave the RV sitting outside, so my "planned" 8' side walls went to 12' so the RV fit under the loft. This increased the complications for the loft supporting a load and was looking like my plans were over.
Then I found this company called Scocket Systems in PA. I called them several times and had in-depth conversations about what I wanted to do and eventually, we drew up plans and I purchased the building system from them. Unfortunately, the owner passed away in 2016 and the company is now closed.
The brackets were all standard Scocket System parts, but then the gambrel steel I-beam roof frames and loft floor I-beam was fabricated by Scocket Systems supplier. Even with this, all the steel and the kit, delivered to me from PA. was only $9k. Therefore, I saved $18k in just roof trusses.
Thats all I got for now. IF I think of more I'll post it.
MI-Trailblazer
MI-Trailblazer
305
1,508
Parma, MI
Good use of what you have there Tramguage! I think the doors I have hung came with some measurements that helped with figuring the track placement. I'm not going to say I did the math right, for the doors I hung did not really work right.😖
Also a little update- this is currently what the inside of my shop has looked like for probably the last 8 years. Hence my need to finish things and get organized:
Current mess in barn
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I found out when hanging rollup doors you install the brackets that hold the door, then center it in the hole. Next pre tention the door slightly and block it from spinning. Next cut the wrapping and let about 1-1/2 to 2 foot of the door down. Install the tracks leaving about 3/8" gap on both sides. Install the upper stops and let the dor up to stops and instal last track screws.
Hardest pat is putting the doors on the mounting brackets.
FYI some doors you mount the upper brackets and door to the tracks and stand it all up in one assembly.
20250117 104110
MI-Trailblazer
MI-Trailblazer
305
1,508
Parma, MI
Nice progress there Tramguage! Love the use of the lean-to over hangs to get stuff out of the sun and weather. I may end up with a lean-to off the side of my shop as well.
Worked great at my horse barn. Took the 40' x 32' pole barn and put 20' lean-to's off both 40' sides. Closed one in and made 2 stalls and a tack room inside, then left the other open and put all the farm field equipment under it. Also use that open space for extra hay storage.
DRZRon1
DRZRon1
1,445
4,418
PA
somebody on here inspired me to update my house garage last month - was all studs - had some shiplap scraps left over and cobbled an American flag together !!!
IMG 2857
IMG 2831
IMG 2856
IMG 3040
E
eolesen
127
448
People's Republic of Illinois
We are about to start clearing ground for our 30x50 deep shop. Talking with Summertown Metals, who does a lot of buildings in the area.
Anyone ever do just gravel on the inside instead of a slab, or add the slab later? Apparently that's something the builder does (pours the slab after the building is up) so we could defer 10K in spending now....
Sent from my SM-S911U using Tapatalk
Tramguage1
Tramguage1
Texan
7,601
31,483
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I would say if the difference between building or not, i would say the slab could be added when you comfortable.
195,558
Built a ton of commercial bldgs where we would get the shell up and then blast them with heat in the winter to thaw the pad for concrete. Generally you have to pump the concrete in or use buggies.
WagginTail
WagginTail
1,652
6,061
SC
We built the roof on ours and are now getting ready for concrete and then will close it in. Just do what you can when you can.
DRZRon1
DRZRon1
1,445
4,418
PA
I almost thought putting the floor/slab down was last step anyway - nothing wrong with gravel and pay/do what you can in time
my pole barn was gravel for 6 months until I got the jingle saved up for concrete
E
eolesen
127
448
Thanks... since half the shop will be for storing the camper and some toys, I might just keep that as gravel and save $5K. That's enough for a couple used Ranchers.
