Warn back up atv light
Blaino517
Blaino517
Prairieville Louisiana
Just installed this on the pioneer! Had to use some extra wire due to it being for an atv and I mounted it under the bed on a bracket!! So far I'm impressed with it! It's pretty far out of the way and it's just bright enough I think, if I moved it further back or to the top it would be brighter but I kind of like it hidden down there, plus it was really easy to install it under there E4094c001acfb27acd45ee79a20e33402f8f455686b46ea0b355c4f5e4ecea19585a8eb6a1b093984d00653c50518312
That is pretty nice. I like the flood beam of the light.
Nice job.
bobbyhill
bobbyhill
Junior Moderator
1,271
953
Smithfield, VA
Great Idea!! If you can find a place to mount away from the muffler, you should get more light over to the drivers side. Just a thought!
p500fan
p500fan
417
354
Sand Point, AK
I like it! If you've ever backed up on a tight trail at night, you would see the value of this.
allgm1
allgm1
1,049
1,485
New Hampshire
that light looks like it does a good job, did you wire it to a toggle switch?
Blaino517
Blaino517
Yeah I could have mounted it further back but I would have had to do some drilling, that's the easiest spot to mount it and so far it's good enough for me, I did run extra wire just in case I decided to move it later on
Reactions: bobbyhill
Blaino517
Blaino517
It came with a toggle switch I mounted that on the plate with the warning label! The kit comes with a wiring harness for a 4wheeler, the light and the toggle switch and runs for I think $30 at cabelas... I'm happy with it for the price!
