AMink
While out riding on Memorial Day we used all of the suspension and quite a bit of the stock skid plates during some rousing trail rides. When we got home I was doing an engine and subtrans oil change. When I got to the subtrans drain bolt it was barely finger tight. Apparently I hit a rock hard enough that it pushed the skid plate up and knicked the very edge of the drain bolt, enough to start loosening it.
Obviously it could have been WAY worse (crack the case, lose the bolt) but I skated by on dumb luck. If you bottom hard it may be worth checking bolts. I'll also be looking into better skid protection.
