Water pump replacement
Snuggs
Arkansas
Trying to replace water pump witch is in the alternator housing and I can’t seem to get it off any advice, do I have to remove the stator bolt ???
CBBCB511 6E81 43C5 ADA7 EAA941CBD5DD
Reactions: Biteme
67,187
Why are you replacing it?
Is it leaking? How bad?
There has not been many reports of the seals going bad like the 700's and rincons do.
If its just a single drop after a ride... I would live with it. If it is a puddle... they yes replace.
Its common for the weep tube to be wet amd occasionally drop.
Anyways. Its a job and you are just starting...
Next step it the big alternator cover there.
Honda does not offer parts. They say replace the whole cover.
But they also say no seals for the 700 pump. But a good dealer can get seals. But the 700 pump is external. Big difference vs what we have here.
If you find the seals. Please post.
Continue to take and post some pictures of your escape. Lol.
Here is some help.
Reactions: Biteme and TripleB
67,187
Lighting sucks.. so if these images are crap ill reload them tomorrow. 14e8640e3af5386fd55f7f69d70342b967ef979cb2b815a7d0cdb99745e65a004d17bc34aadf9e0e5908a89e3c89fa69
Reactions: Biteme
Snuggs
Arkansas
Thank you , from what I’m seeing in the info you have posted I’ve done everything . Tryed prying pretty aggressive still not luck. All the bolts are out I see it says that it is magnetically attached . But not sure what to do at this point
Reactions: Biteme
67,187
So you pulled this case off? Like I said. Honda says its not repairable and you need to replace the whole case. $250+
8403165a4dd3ffccec5cd6ae66c8e89a
Snuggs
Arkansas
Still haven’t got the ***** off yet . Yes Honda’s says you have to replace the whole thing 272+ new oil and coolant set me back a good 400 .
67,187
Here is the service docs, and about all the help I can give.
  • 13. Alternator-Starter Clutch.pdf
Reactions: chads536
chads536
Pulled mine apart today because the drain hose had a constant drip of coolant. I made the mistake of buying the same water pump seal kit before I pulled it apart. After I got it apart I realized that it doesnt appear to be serviceable unless you have special tools or take it to a machine shop. I ordered a new alternator cover from Mrcycles.com since they were the cheapest I found on the internet. Total came to 223.56 including the gasket and free shipping. I attached some photos of the alternator cover so everyone can see what the water pump looks like on the inside. I am pointing to the end of the water pump in the one photo. You can tell the shaft is placed in a part of the housing that is cast and looks like it would break pretty easy trying to take it out.
Hopes this post helps everyone!
Honda 2018 Alternator Cover 2
Honda 2018 Alternator Cover 3
Honda 2018 Alternator Cover 4
