P500 What’s everyone doing for music?
GAug440
GAug440
21
112
Wi
Wanted to follow up on this one for anyone curious how they turned out.
I took them out for our first ride in the machine and they were problematic. They wouldn’t stay paired together and the sound is almost all tweeter with a tiny bit of middle range. While driving I didn’t have to max it out on volume but it was close. I did like the bushwhacker straps though.
For an inexpensive solution it was worth experimenting with but I’m back to looking.
I was considering the MTX sound bar since it’s low profile and tucks under the roof but it’s not well reinforced and can split apart. Currently leaning towards the Wet Sounds sound bar with 6 speakers. It’s made of aluminum, low profile and seems to have great sound. Plug and play with a built in amp and Bluetooth receiver. Time to crank up the budget and the level of effort I guess. haha
Sorry to hear the speaker idea didn’t work out for you, I’ve had no problem with the two speakers linking up (knock on wood). I agree the sound quality will not be mistaken for a full power ‘thumping’ set up and it does show its limitations when cruising at full speed when the noise levels are highest...but for me that’s the time I’m not really listening to the music anyway. Good luck in your search!
johnnyrockets
23
61
New Hampshire
Consider adding the sub to the WetSounds, it'll sound a lot better.
Good idea. Where to put it though? Under the seat or in a separate utility box in the bed? I saw somewhere a specific under seat unit for the 500 from a different company. If using the wet sounds one, I guess it would have to be a custom mount then, right?
Reactions: trigger
johnnyrockets
23
61
New Hampshire
No worries man! It was worth a shot.
182,468
Reactions: Remington
K
kyote
66
241
La Porte TX
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
Anywhere to get these currently? That link is busted and the url comes up scammy on Google.
Might be gone, got mine on Polaris clearance 3 yrs ago, if none on ebay, then unlikely.
E8F69C23 ED7A 4D48 827F 7FF14B059099
I’ve been doing a bunch of research on options for getting tunes in my new 520. I’m wondering what you guys have come up with.
Sound bars have some appeal since they’re all inclusive but they take away most of the real estate available on the roll bar for other accessories and are expensive for the better ones.
There’s some interesting stuff out there with headless or minimal remotes using Bluetooth. The marine audio stuff seems like a good place to look. I’m liking the idea of a small amp with a little mounted remote. There are units that come with both but then you have to get creative with the speaker install.
There’s also those speaker pod setups or “wake tower” setups. Seems like they would be in the way in these small cabs though.
Then there are the under the roof systems with the speakers and head unit in an enclosure, but I’m not sure how they get mounted.
Lots of options out there, but everything has pros and cons. What did you guys settle on? How’d it turn out?
Soundbars in all mine, sound great unless you’re a champagne sound guy....
CaboJim
CaboJim
87
251
53
Washougal WA
After a lot of research, i still couldn’t decide what to do for sound. Decided I’d try two Bluetooth Speakers (Aomais brand) off of Amazon, $52 for two, and $20 for the roll bar straps. I’m very happy with how they work and sound. The speakers link together for stereo sound, are waterproof, and run time is good. Plus you can take them off easily and use them elsewhere. I brought it out ice fishing last weekend, and every one immediately went on line and ordered the same set up. Obviously the sound is not the same as an installed high power amp, sub system... but works great for what I need. Especially for the price.
I have this exact setup. I love it. This speaker last a long time on a single charge.
futzin
futzin
4,300
31,837
Kentucky
JBL Extreme bluetooth speaker. Excellent sound, great bass response and volume. Super simple. I zip tied one months ago and have left it there. Buy 2 and pair them together for 'maximum effort' . . . :p
Just gonna leave this here...
...and one is plenty!
Bingy
Bingy
10
Salem, Utah
This is what running...SSV Works head unit. Doesn't put out a lot of power but it works. E46e2f65c3fdf127b3699820116e7668
Sent from my Pixel 4a (5G) using Tapatalk
KYhillbilly
KYhillbilly
553
1,663
Ashland, KY
Noise cancelling Bose ear buds or my AXIL bluetooth earplugs for shooting. Can hear the music and save what hearing I have left. Also don't disturb anyone else with my taste in music. Use a UE Boom or Monster blue tooth speaker when parked if we want to share music.
