F
I picked up this BigRed as a project. Completely tore it down, cleaned every part of the engine, replaced what was worn out, and built it back up. New cylinder, piston, and rings. New camshaft. New valve seals. The engine smokes like a freight train; lightly at idle and heavily under any throttle. I'm at a loss and am about to throw in the towel and let the Honda Powersports shop take it from here. First, I want to gather as many possibilities for the smoking and see if there is something I might have missed.
Here's what I have done and currently know:
- Brand new cylinder, piston, and rings. All were "matched"
- New gaskets
- Brand new camshaft
- All new air cleaner parts
- Valve clearances set (though they are probably out again since I have been messing with it)
- Spark plug was new at rebuild and is definitely carbon fouled now (matte black tip), but no carbon buildup in the combustion chamber
- Compression is at 100psi (which is higher than the manual states, but I believe the jug/piston is a plus-size)
- Using genuine Honda GN4 oil
- No oil in coolant and no coolant in oil
- Leakdown seemed to have a leak at the exhaust side so I replace all 4 valve seals (have NOT done another leakdown since the new seals, but will be doing that today)
- Have tried various timings between both extremes
- If I pull the plug and turn the engine over, I get a fuel mist out of the plug hole, but NO oil in the mist (paper-tested)
- Smoke is not blue. It's more of a thick gray, but it's definitely burning oil and coolant level has NOT changed
- It did NOT smoke at all immediately after the rebuild, but started to smoke slowly soon after. First it would smoke at idle and it would clear after running. Over time, it became worse to where it smokes at idle and even worse under throttle.
I'm really thinking that it is the rings. The cylinder still looks brand new (which it is brand new) and I have good compression, though, so that has me questioning it. This is probably beyond my shade-tree mechanic skill, but maybe I'm just missing something simple. Any thoughts?
- New gaskets
