Scoop
Scoop
5,401
21,264
  3. Talon R LV
Installed my mobile VHF/UHF radio and antenna. No need to duplicate the info, so details are here in my build thread.
1680920158723
RoundMtn
31
82
Maine
Mounted my side lights but they stick out past the frame about an inch. Is there a better place to mount them? Because I know they will get ripped off first time I go through the tight spot that is my main access to trails.
RoundMtn
31
82
Maine
Stereo done too
I went with the eco gear 32 and it sounds awesome…. I used the roll bar clip on mounts I got on Amazon for mounting on back roll bar. Power cord too short so had to add about two feet of wire.
RoundMtn
31
82
Maine
Finished wiring Duel Battery, Isolator, fuse box, front rear and side LED lights.
Stereo tonight
What a mess under my hood…. Wires and zip ties everywhere. Wondering what water and mud gonna do to new fuse box, battery isolator and relay.
tromano1706
tromano1706
38
157
Virginia
I've been working on a bunch of additions after what turned out to be a less than prepared trip to Hatfield. We ended up getting stuck on the wrong side of a river that we couldn't cross in the dark and after heavy rain. That prompted a lot of additions to be better prepared for the future:
1. Club store back up light (excellent and super easy addition)
2. Nilight Light Bar (https://www.amazon.com/dp/B07TDJP5W3?tag=sxsweb24-20)
3. Club store high beam harness tap
4. Powered windshield wiper from ford escape with 3D printed housing
5. Boss Audio 34" Speaker (https://www.amazon.com/dp/B081G8X5HZ?tag=sxsweb24-20)
6. Club store dual battery isolator (and mighty max battery)
7. Fox QS3
8. Synthetic winch line
The light bar is far brighter than I expected and I made a mount for it out of 1/4 steel and is extremely solid. Pictures show no lights compared to regular LED low beams and then light bar and high beams.
IMG 8239
IMG 0282
IMG 0280
IMG 0279
The wiper was far more work than I was expecting but definitely happy to have it finished now. I even included a plug in case we want to remove the windshield.
IMG 8348
IMG 8350
We have a Samsung tablet that fits perfectly in the you're going to die sticker and held in place with velcro. It its completely flush and I did not want to put switches there.
IMG 8272
Last but not least, the Fox shocks are amazing. Took it for a ride this past weekend and what a difference! Washboard gravel roads completely disappeared. It is way smoother and so much comfortable and I would highly recommend that anyone thinking about it do it. They only took an hour to swap all four corners.
IMG 8367
tromano1706
tromano1706
38
157
Virginia
Nice work on the brackets. Consider tying those two together with a pc of threaded rod though. Those bolts into the light tend to back out, it's happened to several of us, tying the brackets together is the solution.
View attachment 382858View attachment 382859
Thank you! I was concerned about that but hadn't thought of simply tying the two together like that.
Bighat
Bighat
908
3,865
Gallipolis Ohio
116,572
Finished this last weekend. Its in my build, I wanted to post it here as well. Installed New skids from @SuperATV and updated my heater to a RC heater and built a plate for the front ducts to match the plate I made for my switches some years ago. Got rid of my light bar as well and added these RC in the bumper lights. I must say there quite bright.
IMG 6049
IMG 6050
IMG 6051
