ToddACimer
ToddACimer
Pioneer 1005-2
3,809
16,209
Oshkosh, Wi
Part number please
PXL 20220408 2201445322
Kal
Kal
209
738
AZ
I don't think so. If I could pack a gun for every occasion you may run into I need at least 5-6 of them.
The more I think about it the more I need. Two pistols, long range rifle, short range rifle, brush gun, all hell breaks loose gun, shotgun, shotgun with attitude... Hell there's seven right there. :D
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,240
hondasxs.com
Ride Report later.
Have a weld fix for a friend to do today.
Quick pavement ride says quieter no speed loss, a bit rougher ride and the rear is about a 1/4" smaller than the 2.0 Horns, while the front are about an half inch taller than the 27" Horns.
Beadlock rims, don't seem heavier than LE rim. I did not weigh them.
I haven't adjusted pressure yet.
Full 3/4" tread depth
The 28x10x14 Tusk Terrabite tire and wheels weigh 3 pounds more than the OEM LE 27x11 - 27x9x14. (42 vs 39) on a scale.
Now that I've had time to measure exactly, the 28" Tusk are also 1/2" taller than OEM Bighorns.
They are a little square out of the box and hopped until I got a few miles and adjusted all to 13 pounds.
Edit - make sure you torque the bead locks. Mine were loose. Do one offset rotation at 10lbs, then a final rotation at 20lbs.
WagginTail
WagginTail
1,648
6,055
SC
Now that I've had time to measure exactly, the 28" Tusk are also 1/2" taller than OEM 27" Bighorns.
What is the total height on the terrabites? My oem bighorns measured only 25.5". My new blackwaters measure 28". Both measurements taken mounted on the machine
JenElio
JenElio
81,891
712,906
Loxahatchee, florida
When I tow the buggy on my flat trailers in the hot summer weather, the front of the roof tries to lift at 75, so I built a bracket to hold it down and forget about looking at it all day on a long trip. Slow down?? No way.
Until I spring for a cargo trailer.
That's a pretty good solution to your issue. I used to think mine would want to fly off also but I've rode next to it while my buddy pulled it down the highway and it doesn't act up at all. I've towed quite a bit and all open trailer, on open road minimum is 75 for us........like I said though this is a pretty good idea, going to bookmark this for future 😉 thanks 👍
Dirtstiffs-1000
Dirtstiffs-1000
1,729
6,240
hondasxs.com
Last summer we took it back to the ranch in Wyo. Great time but it was 110 degrees across hideaho on the way back and the nose of the roof started to tweak up a bit in the heat. At 75 in Wyo or Montana, the over the road guys blow you away.
I tow it all the time with no issues. But now, I look back less. Kinda anal that way.
JenElio
JenElio
81,891
712,906
I tow it all the time with no issues. Now I look back less. Kinda anal that way.
Damn!! Well in my defense I don't think I've ever towed it at that heat index....🤔.....I don't think I've hit triple digits while towing so yeah I can see how that would be an issue.
Only issue we've had with heat is I've noticed my buddy's buggy his roof started to cave in a little bit one time at the very center right behind where it "puddles". It'd been sitting out for 2 days in the hot south FL summer heat when we noticed
