G
Part number pleaseFrom Honda
For a Hondadollars
Part number please
Is 4 guns gonna be enough?Overhead gun rack, holds 2 more rifles.View attachment 328961
Charging port for Battery Tender.View attachment 328959
My home made switch panel. It came out okay, could have been better.View attachment 328960
I don't think so. If I could pack a gun for every occasion you may run into I need at least 5-6 of them.Is 4 guns gonna be enough?
The more I think about it the more I need. Two pistols, long range rifle, short range rifle, brush gun, all hell breaks loose gun, shotgun, shotgun with attitude... Hell there's seven right there.I don't think so. If I could pack a gun for every occasion you may run into I need at least 5-6 of them.
At minimum lolThe more I think about it the more I need. Two pistols, long range rifle, short range rifle, brush gun, all hell breaks loose gun, shotgun, shotgun with attitude... Hell there's seven right there.![]()
Amen! 👍At minimum lol
As long as my passengers can manage their rifles, 4 should be enough for me.Is 4 guns gonna be enough?
Well I'm still alive but she ain't happy...I ordered one of those moose brush guards this morning. The wife is going to kill me when she finds out...![]()
The 28x10x14 Tusk Terrabite tire and wheels weigh 3 pounds more than the OEM LE 27x11 - 27x9x14. (42 vs 39) on a scale.Ride Report later.
Have a weld fix for a friend to do today.
Quick pavement ride says quieter no speed loss, a bit rougher ride and the rear is about a 1/4" smaller than the 2.0 Horns, while the front are about an half inch taller than the 27" Horns.
Beadlock rims, don't seem heavier than LE rim. I did not weigh them.
I haven't adjusted pressure yet.
Full 3/4" tread depth
What is the total height on the terrabites? My oem bighorns measured only 25.5". My new blackwaters measure 28". Both measurements taken mounted on the machineThe 28x10x14 Tusk Terrabite tire and wheels weigh 3 pounds more than the OEM LE 27x11 - 27x9x14. (42 vs 39) on a scale.
Now that I've had time to measure exactly, the 28" Tusk are also 1/2" taller than OEM 27" Bighorns.
They are a little square out of the box and hopped until I got a few miles and adjusted all to 13 pounds.
When I tow the buggy on my flat trailers in the hot summer weather, the front of the roof tries to lift at 75, so I built a bracket to hold it down and forget about looking at it all day on a long trip. Slow down?? No way.
That's a pretty good solution to your issue. I used to think mine would want to fly off also but I've rode next to it while my buddy pulled it down the highway and it doesn't act up at all. I've towed quite a bit and all open trailer, on open road minimum is 75 for us........like I said though this is a pretty good idea, going to bookmark this for future 😉 thanks 👍Until I spring for a cargo trailer.
Last summer we took it back to the ranch in Wyo. Great time but it was 110 degrees across hideaho on the way back and the nose of the roof started to tweak up a bit in the heat. At 75 in Wyo or Montana, the over the road guys blow you away.That's a pretty good solution to your issue. I used to think mine would want to fly off also but I've rode next to it while my buddy pulled it down the highway and it doesn't act up at all. I've towed quite a bit and all open trailer, on open road minimum is 75 for us........like I said though this is a pretty good idea, going to bookmark this for future 😉 thanks 👍
Damn!! Well in my defense I don't think I've ever towed it at that heat index....🤔.....I don't think I've hit triple digits while towing so yeah I can see how that would be an issue.Last summer we took it back to the ranch in Wyo. Great time but it was 110 degrees across hideaho on the way back and the nose of the roof started to tweak up a bit in the heat.
I tow it all the time with no issues. Now I look back less. Kinda anal that way.
