chucksmith0706
281
1,082
Louisiana
Great points I didn’t even think of that actually. I try and not ride any deep water. I’ll look at turning hose now. I also have some small sheet of ABS I could fab up a cover. I like the idea of having a pre filter. More to come. Thanks for help and information/ideas.
JenElio
JenElio
65,135
609,443
Loxahatchee, florida
Where can you buy? Don't see on web site? I am probably at wrong site thank you!
I don't know what or who you're asking but you have to "tag" the person you're wanting to hear from in order for them to notice your question. Example....@NAME or just simply reply to their message and ask away.
Good luck 👍
Dirtstiffs-1000
Dirtstiffs-1000
1,563
5,696
hondasxs.com
DIY heat shield I assume??? That looks a lot better than the DEI Heat Shield I bought!!!
Yes, DIY,
I bought a roll of automotive heat reflective material and a Walmart window shade.
Rolled them out on the garage floor, laid the seat on top and traced the shape, cut them out with good shear scissors, and it works pretty well.
Also installed a blower under the seat.
Good luck
Scoop
Scoop
4,241
15,891
  3. Talon R LV
That's my next/last step. If the Berryman Seal-r works, I'll let it be and just buy something different when the time comes. By the time I deal with dismounting, returning, mounting, balancing, and all that mess, it's not worth the hassle.
It's been five days and the tires that were s-l-o-w-l-y leaking down (very visibly) within 3-4 days seem to be holding after adding the Berryman Seal-r and driving around about ~10 miles before parking the P1K5. Gonna give it a few more days before I dare to feel confident and check the pressures.
Scoop
Scoop
4,241
15,891
  3. Talon R LV
What did I do with my Pioneer 1000-5 today?
Oh, I used it to help make a made a minor adjustment to my pontoon boat after a bit of bad weather rolled through here late Friday night:
20230825 070642 20230825 070530 20230825 165425 20230825 165603 20230825 165842 20230825 170344 20230825 172222
Putting Piney to work. The two guys on the barge spent damn near 3 hours screwing around and could not get it past vertical. I told them to hold on while I hooked up the winch and pulled it over.
Caper
Caper
7,788
11,001
Halifax Nova Scotia
My Blackwaters had leaks from the start. I took it back to pro cycle and told them they had to resell them around the rim. Three didn't leak, left front did . Not a lot but did. I took it back 3 more times and they would put the tire in the tank , and surprisingly no leaks. But overtime, it leaked. I had it in for service and asked them to resell it. A young guy put it in the tank and said all low pressure tires leak a little. I said you go on the floor every week and fill the tires on the new bikes. No answer. So I asked why he didn't do what I asked to service. They made him take off the tire and resell it. No leaks. I know because he put the Tigre on backwards, with the yellow Blackwaters inside. Hard to get good help.
Caper
Dirtstiffs-1000
Dirtstiffs-1000
1,563
5,696
hondasxs.com
Pulled off the Sheepherder (Farm) jack and replaced it with a Tusk scissor jack.
Figured it'd rarely get used anyway, so why not drop a few pounds and create more space. The farm jack was easier to un mount and mount.
I'm coming off major gut surgery and haven't got my core strength back.
Cheers!
20230826 150301
Dirtstiffs-1000
Dirtstiffs-1000
1,563
5,696
hondasxs.com
