JoeyL
JoeyL
276
741
Houston
Joey,
Do you mind measuring how far out the fender flares stick out. I've got mudbusters but they are pretty wide and our trails are narrow. Several bridges I run tight against. Entrances are also 60" or less.
Thinking about switching to flares.
Thanks
no problem, i can measure it tonight when i get back home.
Reactions: Isaiah
Hondoman
Hondoman
727
1,695
Texas
Extended the gastank, sgas tank, shift box, and rear diff vents. I'm not snorkeling mine or intending to use it as a boat so I left the fan and front diff where they were.
Also installed the OEM winch. Next will be the dual battery and isolator which will take a little planning as I'm not moving the prefilter and box under the hood.
It can be done fairly easy. I didnt want to snorkel mine either.
20200224 180618
Reactions: Isaiah
Hondoman
Hondoman
727
1,695
Texas
Got back on my tailgate stregththening/tailgate extender project. Need to add latches to the extender tailgate and support bars for the loaded weight of the extender, then finish painting. I think I'll add a strip of angle iron to act as a "cap" for the top of the oem tailgate. I sized it to accommodate an rtic 65 with the rear seats up if ever needed.
20200224 170022
20200224 170609
20200224 170656 20200224 170926 20200224 172012
Hondoman
Hondoman
727
1,695
Texas
What brand is it?
All seasons feeders
The galvanized line is not so good (thin, non-welded) but the painted line is much better (welded steel).
Reactions: Russ989
Russ989
Russ989
22,565
146,496
All seasons feeders
The galvanized line is not so good (then, non-welded) but the painted line is much better (welded steel).
Thanks
Reactions: Hondoman
Vikes79
Vikes79
SKOL!
10,846
105,249
South Dakota
They make it look like a totally different machine. Nice work
Thanks!
After a lot of help from previous posts and the links of @JACKAL, I was able to build at kit that installed exactly the same way as the now discontinued red panel kit Honda used to sell for base models.
You won’t have to replace the doors using the kit. You just need to make sure your well nuts are tight fit when installing them.
Details and parts are in my posts in this thread.
Reactions: JenElio and Isaiah
