Finally got the right axle apart. Although the grease was a bit thin for my liking, the joint seemed well coated. However, there are visible signs of problems and obvious why they make noise.
The outer joint was tight and looked just fine. The inner is another story. The outer housing showed some minor (normal) wear but nothing that made me worry. However, the inner race and Balls are toast. I have never seen cv balls turn black like that and I am going to say it is heat related. I think that either the lube they use is garbage or the tolerances are too tight and cause heat and premature wear (or maybe a little of both)...
Here is the most damaged part of the race. The scarring is on the forward drive side, reverse side just shows normal wear. The little, out of focus part is a metal fragment from the race...
The balls tell more of the story. Left is the inner (bad) joint and right is the outer. Black and pitted/scarred tell me a bit of heat was generated at one time...
UGH, another bad Honda engineered/manufactured part. This $HIT (and the driveline crap) are so basic and easy to solve, doesn't Honda have any forensic engineers???
