What is this wire under hood for? Blue tape wire
Russ989
Russ989
22,645
147,291
68,245
I got Zero.
Key on or off, between blue tape wire and battery ground or frame ground.
Zero with test light to battery ground also.
Reactions: Adam490 and Russ989
62,453
Mine was zero when I checked it before I used it as a common ground.
HondaTech
That is the factory "included" ground to aid installation of the Honda winch kit.
I have no idea why there is any voltage at that wire. Id assume it's not currently attached to any accessory?
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,543
Central Iowa
We are still waiting to hear how the guy got a reading of 9 volts..... @chops450
I wonder if the multi-meter switched over and actually said mv....? sometimes a ground will show a mili-volt reading that's basically zero but not quite.
But yes the blue tape wire is a factory ground as you all have said. I've had mine hooked to my winch solenoid for over 18 months.
Reactions: Mudwing
chops450
You're the winner.... Sorry for the delay I just got home from work. It is zero... Worst part is I already wired my winch so no I have to fix that lol no worries... Thanks for everyone's help!!
