P1000 what rpm does your clutch engage
pct
pct
Lost in the hills
790
1,023
Letart WV
I was wondering if it just mine of is anyone noticed how there clutch engages mine it reves up and jerks like popping the clutch and if it idles down it releases anyone else having this happen calling the dealer to check on this it would be a problem on the trails running slow
Bayouownbeer
Bayouownbeer
798
1,123
Chauvin LA
It souldnt do that. Should engage softly. Is it only when you first take off?
283,594
Sounds like the sub-transmission isn't fully engaged then jumps into gear. May need the shift lever cable adjusted that goes from P/R/N/H/L.
dale5740
dale5740
886
417
mt airy md
I noticed mine one time I put it in reverse looked over my shoulder and hit the gass it just raved up then out to drive back to reverse did it again then pop in it went and hasn't done it again since but haven't ridden much either
