What the ...Hey
waynester
waynester
254
1,250
Ga, USA
Please explain why superatv instructions have bolts installed protruding 3/4+ in. below skid plate? While in for services had superatv full skid plate installed , as per instructions this is what I have, 6 hard steel spikes to grab ,shear off or rip off skid plate, 3 on each side directly behind front wheels. How will this slide across logs and rocks, least of all dirt ? Seems insane at the least, criminal at worst.
Inbox 4 521 waynester58 gmail com Gmail 20220507 103005 resized 20220507 103023 resized 20220507 103126 resized
115,388
@SuperATV
there tagged him for you to get an answer. Wont be till Monday tho.
I will ask you, why dont you just flip them the other way? Or is it too much of a whore to do?
waynester
waynester
254
1,250
Ga, USA
@SuperATV
That's what I intend to try. My BP is up due to: I already paid to have it done (no dealer blame for following OEM instructions) > I'm somewhat Physically limited, special tools for safely lifting and outside gravel covered work area AND that was a early piece installed , so first thought it will need to be last removed, .....I'm disappointed and blowing steam for now
TOGR
TOGR
81
406
53
NW Montana
  1. Talon R LV
Sure doesn't look right.
Hopefully they are at least metric fasteners. Can not believe how many aftermarket items use SAE fasteners. It is one of my biggest gripes (oh yeah, and these are not "bikes"...).
JMynes
JMynes
544
3,238
Augusta, Maine
For many years all we had was SAE fasteners, and they worked fine.
Those were the good old days, when I only needed one set of wrenches.
onecreeper
onecreeper
479
2,543
Kansas City, MO
I think that was his point. You buy something, get it installed then have to do more work. The original question was WHY would it be designed that way? Then again, you can never underestimate the shops inability to think and make a suggestion either vs. just doing it and moving it out.
TOGR
TOGR
81
406
53
NW Montana
  1. Talon R LV
Ah the good ol' days--just SAE (and Whitworth).
Yeah, then came the Japanese and the Euros, now even my Ford is pretty much metric.
If making a product for a specific vehicle that is SAE--use SAE, if metric--use metric. Duh! Otherwise we not only have to have 2 sets of tools, we now also have to CARRY two sets.
That would solve it--now just not sure what to do with my Whitworth tools :( (not requesting SA ideas!)
115,388
Yeah, they definitely installed them the wrong way. Sorry buddy. I'll check on those instructions...but yeah, definitely installed the wrong direction.
Jim Dandy to the rescue!
GO Jim Dandy GO Jim Dandy
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,112
21,246
Route 66 Oklahoma
I remember listening to the original on the radio In 1955 (I had to look it up). I had a crystal radio using my bed springs for an antenna. 😁
Russ989
Russ989
22,642
147,257
View attachment 333110 View attachment 333111 View attachment 333112 View attachment 333113
That will snag you in the first mile of trail, I’d do something different.
322,690
I’ll admit sometimes the SuperAtv instructions leave some for the imagination but that’s retarded a “paid professional”
Installed like that. I mean does no one have any damn common sense anymore. Anyways that’s a bit of a safety hazard, if it catches at the wrong place can mess your day up. As a customer you’re right, if you pushed hard enough they should’ve fixed it. Stupid stealerships
Farmer
Farmer
2,907
16,768
Southern MO
An engineer (the guy writing the directions) will probably say that's how you fight gravity to reduce failure. In many cases that's the proper way to use gravity to keep the bolt in if the LOCKnut's somehow fall off. Think of it like a hitch pin. But in the real world and this application that's complete BS and I'm guessing the dealer had the young punk installing your add ons. No experienced mechanic would follow those directions and install this way.
Farmer
Farmer
2,907
16,768
Southern MO
..............Installed like that. I mean does no one have any damn common sense anymore. Anyways that’s a bit of a safety hazard, if it catches at the wrong place can mess your day up. ............
Yep, I could even see them pulling and damaging the frame holes. Gotta swap that mess and then go slap the moron who installed them.
