What's this?
nbomar
nbomar
4,416
17,854
Springdale, AR
Looks like a motor mount bolt off of a car the tapered end help line stuff up at the factory during assemble do you own a car?
BMW X5 and a duramax.
nbomar
nbomar
4,416
17,854
Springdale, AR
If there's a duramax around it could either be an exhaust stud or turbo mounting stud and if it's a newer one that has a dpf (it uses def) it could be a dpf mounting stud.
I drive a 2015 duramax...
Maybe a bed bolt?
(Delton) "I HATE light scratches too. Makes me think I left some fun on the table. So I go back out there and cover them up with deep scratches. Works every time lol."
Bed bolts are tapered but not fine thread on one end though
115,789
Although the tapering is correct for a motor mount. The only thing is unless it's for a motor on a Barbi truck it's too small for a motor mount. Those are usually grade 8 fairly large bolts. Good thought though.
Reactions: sharp
nbomar
nbomar
4,416
17,854
Springdale, AR
Could be for a shock mount are you sure if came off of your car and not someone that stopped by maybe
The shock mount makes sense maybe. I lost a upper shock mount a few weeks ago on the highway. Just figured it fell out there. Maybe it has been laying in the frame the whole time... 3308a2f929e2742930e3a25693958c01
Reactions: Tigermark and JTW
nbomar
nbomar
4,416
17,854
Springdale, AR
Well it's not a shock bolt. It doesn't match the side I still have so back to the drawing board.
Reactions: sharp
115,789
Still looks like an exhaust manifold stud by its size and threaded on one side that is now stripped that was in the head and a solid space after that . They're easily stripped in today's aluminum heads, and the nut on the other that is usually matching black. Like knuckledeep said with manufacturing for motor mounting, the "tip" same goes for assembly line for headers/manifolds and intakes. I have a box of assorted types left in my tool box from when I was at Roush. Check all your manifold and intake studs to be safe. There's quite a few on today's engines one being removed won't be noticeable with a noise. I could be wrong! Just a familiar item.
Reactions: sharp
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Maybe it's an exhaust pipe bolt for either one of your vehicles
Reactions: Remington
