P1000 Wheel bearing tool
Toddwis
6
Illinois
Hey everyone! First time posting but I’ve been enjoying the site for awhile now. I wanted to grease the wheel bearings on my 2021 P1K-5. I bought the 40mm greasing tool from Amazon and it’s too small. Everything I’ve researched is says the 40mm tool should work. The only other one I’ve found online is a 44mm tool. Does anyone know if that’s the actual size I need? Any help is appreciated. Thanks!
Reactions: Lady01 and TxDoc
Gabbas
Gabbas
280
700
Humboldt, Iowa
I watched DirtNdiesel in youtube and the one he bought and others have linked through the forum is on ebay. HONDA PIONEER 1000 ALL 4 WHEEL BEARING GREASER TOOL axle in! - R | eBay
Sent from my Pixel 4 using Tapatalk
Stateboy
Stateboy
299
1,740
Wolverine, MI
This is what I found in the repair manual. I'm not sure if it will help. Also, welcome from Northern Michigan. 69aa9a9cd847b4e2a37f797a840f7881
Sent from my SM-N960U using Tapatalk
Reactions: Lady01
Toddwis
6
Illinois
I watched that video too. I never found any dimensions listed on the sellers page so I don’t want to buy another 40mm tool that doesn’t fit. He doesn’t tell the dimensions in the video either. I’m curious if the size has changed for the 21 model or I need a different size. I appreciate you responding. Thanks for look into it!
Reactions: Lady01
bigshoe
bigshoe
421
1,426
Done same thing, amazon junk order one off rocky mountian atv the one from there I used fit perfectly
Reactions: Lady01
Toddwis
6
Illinois
This is what I found in the repair manual. I'm not sure if it will help. Also, welcome from Northern Michigan. View attachment 269190
Thank you for the response! Honestly I wish they gave dimensions in the manual. The OD of the tool is just under 1 5/8” so I think the 44mm tool is closer to what I need but I don’t want to order and cross my fingers. It seems like most of the sellers on eBay and Amazon only go to about 2017-2018 in the description so after looking deeper I wondered if the 2021 model maybe had a larger bearing. Thanks again for posting!
Reactions: Lady01
Toddwis
6
Illinois
That makes me feel better. I did quite a bit of research and was pissed when I pulled both front hubs and it didn’t fit. So I put everything back together without accomplishing anything. Could you post the one you bought on the site so I don’t screw up again? If not I’ll look into it. I really appreciate you posting. This site has been a huge help for me when I bought my first Honda SXS in 2015. And has continued to be in my favorites since. I love how everyone helps each other (and busts balls too). BTW I‘m from southern Illinois (didnt call it out earlier).
Enigma
Enigma
East Tennessee Mudder
366
838
Rocky Top
Anyone try the CA Technology wheel bearing tool? It looks like it is a well designed tool.
Reactions: Lady01
107,361
Welcome From Restricted Michigan!
Glad your figuring it out!
Btw, no difference in the barring from 16-21’ ;)
PICS IF YOUR MACHINE OR IT DIDNT HAPPEN!
Reactions: Lady01
TexasJackKin
TexasJackKin
386
3,119
Dayton, NV
When I put the information into the eBay link above I get this:
1619787033886
slowdryrider
slowdryrider
564
757
Canada
The one I ended up getting is 40 mm it supposedly works on Polaris as well. It did work for me too. I did have to pull the hub away from the axle and also had to remove the O- Rings that were on the tool. It did fit into the bearing and it worked perfectly with the o-rings removed. It shows up in french even though I have it translated to english this is what I bought and it works by doing what I mentioned above.
Reactions: Plowboy1466
Toddwis
6
Illinois
I’ll post pics soon. Nothing really special just yet. I have the front cab tore apart for a fan install this weekend. I currently have a BOSS sound bar and amp with two BOSS marine speakers in the back. 28” ripsaws all around with STI rims. A small light bar up front and one behind. After the cooling fan I’d like to add a winch and upgrade shocks too. I bought this machine last year after selling my 700-5(2016). This rig is an entirely different animal and I couldn’t be happier. Quickly put 1200 miles on it and I am getting stuff ready for another year of riding.
Reactions: Remington
Toddwis
6
Illinois
That’s my issue too. Looks like the tool would fit into the bearing but the axel won’t slide through. Didn’t want to pull the hub but it looks like that’s my only option or find the right tool with a larger inner diameter. Usually only the OD is listed for the tool so finding the right one has been a waste of time. Thanks for the reply!
107,361
Were just imagination illiterate, so pics in any state is how we understand things. Its the unwritten bible verse around here. Especially before (intro page) or during your first post! ;)
