P1000 Wheel/Tire pics!
hogfish
hogfish
17
34
florida
35'S
IMG 07941
Sckottty
Sckottty
53
35
Abilene TX
View media item 3183View media item 318112”x8” method 406 with terache altas 28”x12”x11” rear and 28”x12”x9” front
THESE HOOK UP!! I’m so glad I took advice and went with 12” wheels. Makes so much sense, dropped the psi and I climbed trails I struggled with easy. This set up blowers away OEM setup, plus the 2” highlift helps. Fatter tires sure soak up the trail. Once you go Fat, you won’t go back
GPR1500SC
GPR1500SC
861
2,427
North East MO
  2. Talon X LV
How do you like the motoclaws? i love the look and my dealer pushes them!
Depends alot on riding conditions they are tuff as nails I am running 7 to 8 pounds of pressure in them and they still don't flex much.
In the winter when it cold they give a rough ride and don't have much traction compared to the stock big horns.
Overall they are OK, but my next tire I will look for tires that have softer side walls that flex more, sacrificing durability for better ride and more traction.
The only disclaimer is the tires are 29 inch on 16 inch rims so the side walls of the tires are stock size, if they where bigger I think they would work better for me .
Reactions: djracer and BWAF
BWAF
BWAF
I get paid to pass gas
8,869
42,495
Carthage MO
235-75r 15" Fedral couragia Mt all 4 coners on sti hd9 wheels they call them 5x2 offset but it's 30 mm 1" spacers on rear. no lift no a arms just had to add one screw in the factory fender flare and as far as I can tell there's no rubbing going to find out this weekend it SMORR 9psi front 11psi rear looks good .Truck tires feel a little firmer on the road little more responsive. Haven't got to test them out .D302cc8e2e3fb7c5a6aeededb404acdf64e61f30ba206c1429cf382a9f8a846c5e36f762734df24d8732c149a0f352a1B29491cafdba073f57f2302ed4d16e8c78127e638c277839fcbd069a08d644b4
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Has anyone tried the General Grabber Tires on their P1000-5?
It looks like a good alternative
I liked those as well. They we're my 2nd choice.
Reactions: BWAF
