P1000 When taking off in high, makes loud clanking noise
jrihm
9
10
Indiana
Hello i have a 2016 1000 with 8600 miles on it. When taking off in high it makes loud clunking noise and then will take off, sounds like when the reverse went out(which was replaced and upgraded with the talon reverse and low gear about 3000 miles ago) but now it does it in high first gear. It started out doing it a while back once in a grate while, normally from shifting out of reverse to high then gradually does it every time I take off. I thought it might be in the sub trans like the reverse gear was but I just pulled it apart and everything looks great. I can run in low and no issues at all only first taking off in high. Any thoughts?
ODAMO
ODAMO
1,399
3,673
Ohio
Is your cable adjusted so that when in N the shift lever is centered in the N gate on the dash? If it’s not centered adjust so it is and that may solve the issue.
jrihm
9
10
Indiana
I can stop leave it in gear shut it off come back and take off and it makes the same noise, u cam feel it try to grab a gear and eventually it does. Used to only happen under a load or going up a hill now it does it pulling out of the barn
P1K5Dave
P1K5Dave
2,334
8,711
Petoskey, MI
It's hard to imagine what you're hearing, maybe it would benefit to upload a YouTube and post it here. Although, they often don't come across all that well, but maybe a start.
Reactions: JNo323 and ODAMO
ODAMO
ODAMO
1,399
3,673
Ohio
You could change the engine and tranny filters to see if there might be any clutch material indicating a need for number one clutch replacement.
ODAMO
ODAMO
1,399
3,673
Ohio
Like @P1K5Dave said a vid could help a lot.
jrihm
9
10
Indiana
Would a rear locker only do it in High first gear and not reverse or Low gear?
  • Sad
ODAMO
ODAMO
1,399
3,673
Ohio
Typically no, but stranger things have happened.
I’d check the filters.
Have you ever done a clutch relearn? That may help if it’s wear on the clutch
jrihm
9
10
Indiana
I have done the clutch relearn and also have replaced the 135 clutches aways back, I will put the sub trans back in and tree these and if not will get a video so you all can hear it. Thank you for the advice i will keep you posted
Reactions: Smitty335 and ODAMO
P
Prospector16
19
108
New Brunswick, Canada
Does it also make that noise if you start off in manual mode instead of automatic? My 2016 is much smoother when I use manual mode.
0860silverado
964
1,862
louisiana
I'm with ODAMO. Sounds like your rear differential lock is out of adjustment...(cable is too LOOSE). One thing to note that may not be obvious is the fact that the cable pulls and holds the rear diff OUT of lock. If it is not adjusted with enough tension, the locking pawl in the diff will partially engage/disengage, making a pretty nasty popping sound.
Reactions: Smitty335 and CID
212,741
And all I was wondering about is changing out the front splash guards on my P1-5. Really I poked a hole in one and decided to change them both out, the doors have to come off and if I remember right I couldn't get the door frame hinge off when I did the door bushings years ago. Figure since new splash guards are going on, I can butcher the old one to get at the nut welded to the rops and apply a little heat and impact? Any suggestions? Thanks in advance.
jrihm
9
10
Indiana
Good morning, yesterday i put the sub trans back together and back in the pioneer, i didn't do anything else to it except pulled the sub trans, took it apart and inspected everything. I put it all back together and test drove it yesterday and it did great, no noises no grinding. I tried to get it to do what it was doing before and could not. That being said i have no idea what changed but something did and its back to normal, for how long i have no idea but hopefully for good. Thanks everyone for their input and help, i will keep you posted if anything changes. Any thoughts on what it was would be interesting to know.
