P500 Why can't you store anything where it says "no storage" under the seat by the manual?
A
arachnyd
24
82
Ohio
Any idea why you can't store anything under the passenger seat? It says "no storage". I was hoping to just put registration and insurance papers there, and maybe an electrical distribution box and a USB charger. Just curious if anyone has any practical reason why it can't be used for storage? Seems odd to be that it has a "no storage" warning on it. I searched and found nothing.
906UP
906UP
14,241
134,971
da Yoop
Because the world is full of idiots who will drink battery acid unless there's a big azz warning label telling them not to. You'll be fine putting your papers there
The Green Goat
The Green Goat
2,158
15,957
Ohio
If you stored stuff there, then how would you carry around your owner's manual, which is what they intended to go there? You never know, but at a moments notice, you might need that manual.
A
arachnyd
24
82
Ohio
I was generally referring to the giant storage area right behind the manual that says "NO STORAGE".. (I get that the seat has a divot that eats into that a little bit, but it also seems like reasonable space for some small things).
While on many vehicles that might not be referred to as "Giant area", but it is literally the largest storage areas in the 500..
But secondly, seriously registration papers and insurance at least would easily fit alongside the manual...
No Storage
906UP
906UP
14,241
134,971
da Yoop
Mine no longer has that spot, I cut it out so I didn't have to disassemble half the buggy to change the oil, I'm sure the Honda lawyers wouldn't approve but phuck'em 🤣
178,025
The ECU is right there so they don't want some moron putting his spare lighter fluid in there. Not sure but I think you were the one asking about under hood storage too? Both of those areas suck for storage. You're going to want that space under the hood for EPS and such. Plus having to take your hood off to access anything while in a mud hole isn't ideal. There's a lot of space under the drivers seat as well but again, not ideal for storage. Put a box on the back and use those other areas for rarely used items. Check out this thread for some ideas. Welcome to the forum.
115,316
A
arachnyd
24
82
Ohio
Just a wild guess but, if you put something solid in there it would be bouncing on the wires to the ECU.
Probably not good for the longevity of the ECU.
Yes, I do agree, but i was specifically thinking of just a small power distro box and fuse that would screw into the side, letting it be close to the battery and putting my registration and insurance papers there which I probably never need to get out, but then I have them in case I ever get pulled over (which has never happened, but I should have them). Figured it was perfect for that, and sounds like it is. I do get it now, I was trying to figure out if there was something there I just didn't realize (like if it was a catch drain for bed channels or something, which makes no sense, I just couldn't figure out what it could be- but that makes sense just to protect the ECU wires)
Under hood I already have a box, I was just thinking about ordering the glove box and wanted to make sure I didn't have an issue. under the hood, as when you order they make a point that it fits with the OEM under hood box and I wanted to assure that also didn't mean it "only fit with the OEM box and not other boxes". I don't keep stuff I regularly need under the hood since I have to take the windshield off to get it, its more of the "oh sh*t your stranded" type of stuff because I use mine on a farm by myself and need to be able to save myself if I get in a bind far away from others, so spare fuses, emergency tie downs, Less necessary tools (Sockets, wrench sets, tire repair kit, zip ties, spare electrical, tire inflator, radiator stop leak, oil, coolant, spare plug), first aid kit)
Space under the drivers seat is kind of a PITA with the rubber cover (clearly honda engineers WANTED to make it useless so you felt compelled to pay $200 for a storage cubby)- I may but a storage place or may work on hacking something together one of these weekends.
The bed I want to leave open because while I may take it to trails occasionally, I do more farm work on a mountain, and don't want to take up precious bed space or not have that emergency stuff when I need it, despite the fact it adds weight- I am installing a jump seat for when I need to bring people from point A to point B on the farm at 10 MPH on flat land, and then pop it off and use the bed for doing work, and then pop that off and strap in a larger rear box for when doing offroad trails and I want more water tight storage for more gear and extra fuel and stuff. All in all its a good setup to try to do "everything", despite trying to do everything means you do nothing perfectly.
Tom_C
Tom_C
158
473
Virginia, USA
Sorry to resurrect an old thread, but here's what I have done. I was originally looking for the size of trashcan for under seat storage, but I really don't want to cut the Trigger shield, so I bolted an Ammo can to the bed using some quick clamps, and it could go outside the bed/rack if you wanted to save the space. The bungee is until I can figure a way to make it more stable since it wobbles a bit and I wanted to keep it up off the fender so it wouldn't bang around. Then got a net storage for between the seats.
Storage1
Storage2
SILVER_ALERT
SILVER_ALERT
HONDA SXS Club Flounder
3,111
21,234
Route 66 Oklahoma
The net looks like it's handy. Where did you find that?
Reactions: Backwoods
Mudder
Mudder
NTC Ambassador of Walls
11,644
87,858
View attachment 409804View attachment 409805
The trash can size is 3 gal. I did not cut my Triggershield as it easily lifts up when needed for access to the trash can. As @trigger mentioned previously, the underseat storage is good for seldom used stuff, like 12v air pump, 12v water pump with a container of water, etc.
Reactions: trigger and Tom_C
futzin
futzin
4,131
30,691
Kentucky
The trash can size is 3 gal. I did not cut my Triggershield as it easily lifts up when needed for access to the trash can. As @trigger mentioned preciously, the underseat storage is for seldom used stuff, like 12v air pump, 12v water pump with a container of water, etc.
With any due respect, and with tongue firmly in cheek I have to ask: how do you mention preciously? I'd assume, with tongue firmly in cheek to start with!
Sorry, couldn't help it.
Carry on, don't mind me . . .
The Green Goat
The Green Goat
2,158
15,957
Ohio
I'd argue that everything @trigger says, is precious.
