P1000 Will it void my warranty?
rocmar
rocmar
4,741
5,776
4 CORNERS
Most cases it is up to the dealer and they do not involve Honda but if they do warranty could be voided. I would stay away from lift kits and 30" + tall tires if you don't want any problems.
Any alterations of the vehicle. .....gives them the right to
VOID....the warranty
that's a fact
Up2It
Up2It
Calgary Alberta
that's a fact
That isn't accurate. They have to be able to show a link. Big tires and a broken axle? That's a link for sure. Led running lights and a stereo causing a transmission issue? No link at all, unless it was electrical and there was things tied in. All of this is really common sense. That is why all my accessories will only be on my additional battery. I would snorkel my ride without any worry at all,but wouldn't expect warranty if I dusted my motor. (Or had water ingress)
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
I should add that the warranties offered thru my dealer in Chattanooga are the OEM warranty and their own warranty. So, I got the warranty thru Southern Power Sports.
Did you pay 800 for it Joey? That's what I paid.
rocmar
rocmar
4,741
5,776
4 CORNERS
You believe wat ya want....
Tot
Tot
661
462
Des Arc, Arkansas
Each dealer is different from my experience and what warranty you actually get. Some will still cover i.e. broken axle with bigger tires. It's really up to the dealer
Kingmudd
Kingmudd
74
35
Up2 you are correct in your statement I am checking on getting the extended warranty through my dealer and they told me they repair (warranty) anything on the machine that breaks down that's not caused by an accessory or modification. The warranty also states this "If a non-authorized part or accessory caused or contributed to the breakdown or damage" it's not covered.
HondaTech
I'd have anything your dealership told you in writing and notarized. Anything Honda says is in the warranty book you should have been given when you purchased the unit. Anything anyone at that dealership says is null and void if it's not on a piece of paper imo. We tried offering dealer warranty once before but it was such a mess sorting out what Honda should pay or what we should cover that we quit offering it. 9/10 if you've got a good service manager and a good dsm they'll work something out and pay for any issues.
Plumber101010
Plumber101010
597
584
Western NC (Hayesville)
Presently right in middle of this. Dealer days I have a 5 full year warranty. Didn't say of thru Hinda or not but after reading this thread maybe it's not. And he's throwing in 28" bighorns as part of the deal prior to delivery so my interest is peaked now!
Reactions: joeymt33
Z
ZZ15
19
Read the genuine HONDA warranty very carefully as they hide conditions in the fine print. I had one years ago and it required all maintenance to be performed at a Honda dealer using only Honda parts including oil and filters. More or less the warranty I had said it had to be 100% stock. The dealers will tell you anything to sell the warranty as the make a boatload on them. I never needed to use the warranty so it was money down the drain.
