P700 Will not stay running
busbyrl
5
Yulee
I’m not sure how to work this website so I’ve been posting on everything I need some advice on why my 2019 Honda pioneer 700 will not stay running I fell off into big of a hole got water in my fuel tank clean the tank replaced fuel pump assembly With pump Replace fuel injector and fuel line and replace both spark plugs it will run add an idle for about 15 to 20 seconds and shut down if I touch the accelerator pedal at all it will shut off
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Id check the mass air or what ever its called in the intake if it got dirty water in it probably needs cleaned or replaced
busbyrl
5
Yulee
Thank I’ll check and see when I get off work
FeelinRecless
FeelinRecless
182
549
Check the idle air control valve.
cjhampton09
Indiana
  2. Talon X4 LV
Currently having this same issue. What was the fix?
115,780
Good luck with getting an answer From that guy! Like some people, they come on first post is an issue, no Intro and to get some info picking our brains and never return with an update Leaving all hanging. if u look at his profile His join was June 22,2020 and last seen July 1,2020. some think its being an ass but Thats one reason we say,
Pics Or It Didnt Happen!
For you, since this thread hasn't had any activity in over a year and a half, Id start a new thread about your issue to get more definitive answers specifically for your machine. Plus, add pics of that machine And what your solution was when u fix it ;)
