Welcome
@Tinnocker1976! I just came across this. I'm surprised nobody has tried to help. People here are normally all over this type of stuff.
From your post I'm going to guess that you have the remote switch and you are wanting to also have a rocker switch in your dash. A good source for switches is
OTRATTW I'm pretty sure they are who Honda gets their switches from. I haven't verified this, but if you are using the OEM switchplate that mounts in the lower cubby this companies switches should fit in it. If I'm wrong someone here will correct me.
If you are thinking about adding after-market accessories that go beyond what Honda sells, or you just would rather use after-market because they cost less and you aren't limited to what you can get, you really should check out all of the "Build" threads on here. There's some people that have really done an amazing job modifying and building their machines.
@mystic1219 makes switchplates that perfectly fit the area above the cubby where the warning label is. Here's the thread on those
Custom Switch Panels for P700 & P1000
I am currently awaiting my switchplate and switches and will hopefully be installing them this coming weekend. I have the remote winch plug in my glove box, and intend on splicing into the wiring harness to add a dash mounted rocker switch.
