Hi so the MAIN use of the winch on my Pioneer will be for plowing. On my now dead Rhino I am replacing it was a moose plow, 3500Lb winch (TractorSupply) with steel cable.
All worked well except for occasionally IE once a year or every other year the steel cable would break right at the end due I assume to the 90 deg turn the cable had to take coming off of the winch roller.
So I see a few mount options, one from KFI and another from Kolpin, is one better than the other? Mainly want ease of install and ease of access.
Second Steel or rope line? What is best for plowing? I see Kopin makes an auto stop switch for rope line setups, this for sure would help but how is that to use? How is that to wire in?
Winch size - Ive had a 2500lb and a 3500lb, dont see any reason to go larger and honestly the 2500 was quicker to lift the plow, any opinions??
Last the plow, Im on limited budget after spending $12K+ on the UTV so was looking at Kolpin universal plow its under $500. Honda Pioneer/Talon Switchblade Universal Snow Plow System by Kolpin - Everything Honda Offroad
I plan on installing a second battery with an isolator and I see several helpful threads on doing that so I should be able to handle that.
As for the switch to control the winch, does the Pioneer dash have a place for putting switches, is there a faceplate with switch holes already cut available?
Thanks!
Phil
Honda Pioneer/Talon ATV Winch Auto-Stop by Kolpin Outdoors
Built-in Auto-stop technology works to automaically stop your ATV winch at the end of the rope pull or plow lift.
www.everythinghondaoffroad.com
Thanks!
Phil
