I have a superwinch Terra 45sr for my 2020 Pioneer 1000-5 deluxe. What is the best winch mount for this application? I've read on here kfi's mount doesn't allow the synthetic rope to feed straight. Any advice or feedback would be much appreciated.
None of them winch plates in the OEM location feed straight. Been running a Terra 45S for 5 years still on the original synthetic rope with the KFI mount. Unless you are using a snowplow and running the same 12" of rope to raise & lower the plow it is a complete non- issue.I have a superwinch Terra 45sr for my 2020 Pioneer 1000-5 deluxe. What is the best winch mount for this application? I've read on here kfi's mount doesn't allow the synthetic rope to feed straight. Any advice or feedback would be much appreciated.
I have KFI mount and winch for over 4 years with no problemsI have a superwinch Terra 45sr for my 2020 Pioneer 1000-5 deluxe. What is the best winch mount for this application? I've read on here kfi's mount doesn't allow the synthetic rope to feed straight. Any advice or feedback would be much appreciated.
I will be plowing a lot w/ this machine as I live in Northern Minnesota.None of them winch plates in the OEM location feed straight. Been running a Terra 45S for 5 years still on the original synthetic rope with the KFI mount. Unless you are using a snowplow and running the same 12" of rope to raise & lower the plow it is a complete non- issue.
I'm having a hard time getting on warn industries website. Do you know if it is compatible w/ the terra 45? If so where did you buy the Warn mount? ThanksThe Warn winch mount is easy to install and has a better cable angle than the KFI. I had issues with the bolts coming loose on the KFI mount .
I think I'm going to purchase this one. It doesn't list the 2020 p1k-5 for compatibility but it does show 2019's. You think it'll still bolt up? ThanksI used ExtremeMetalProducts to mount the same winch on my 1000-5. I like how it also attached to the front frame of the machine, seems like it would be a stronger setup.
I'd bet my dollar it will.I think I'm going to purchase this one. It doesn't list the 2020 p1k-5 for compatibility but it does show 2019's. You think it'll still bolt up? Thanks
