P1000m5 Winch mount??
slicknik77
slicknik77
Minnesota
I have a superwinch Terra 45sr for my 2020 Pioneer 1000-5 deluxe. What is the best winch mount for this application? I've read on here kfi's mount doesn't allow the synthetic rope to feed straight. Any advice or feedback would be much appreciated.
266,553
None of them winch plates in the OEM location feed straight. Been running a Terra 45S for 5 years still on the original synthetic rope with the KFI mount. Unless you are using a snowplow and running the same 12" of rope to raise & lower the plow it is a complete non- issue.
Reactions: slicknik77
ToddACimer
ToddACimer
Pioneer 1005-2
3,565
14,634
Oshkosh, Wi
The Warn winch mount is easy to install and has a better cable angle than the KFI. I had issues with the bolts coming loose on the KFI mount .
WV1000-5
WV1000-5
11
49
West Virginia
I used ExtremeMetalProducts to mount the same winch on my 1000-5. I like how it also attached to the front frame of the machine, seems like it would be a stronger setup.
sporttrac4x4
sporttrac4x4
1,177
2,082
ILL.
I have KFI mount and winch for over 4 years with no problems
slicknik77
slicknik77
Minnesota
I will be plowing a lot w/ this machine as I live in Northern Minnesota.
slicknik77
slicknik77
Minnesota
I'm having a hard time getting on warn industries website. Do you know if it is compatible w/ the terra 45? If so where did you buy the Warn mount? Thanks
slicknik77
slicknik77
Minnesota
I think I'm going to purchase this one. It doesn't list the 2020 p1k-5 for compatibility but it does show 2019's. You think it'll still bolt up? Thanks
NTCPrezJB
NTCPrezJB
President of #NTC
101,653
907,600
Canton, OH
I'd bet my dollar it will.
bigshoe
bigshoe
421
1,426
Warn is the best I've installed pretty much all brands that seems to fit and work the best
ToddACimer
ToddACimer
Pioneer 1005-2
3,565
14,634
Oshkosh, Wi
I bought mine on Amazon. I used the mount with a Terra45
bigshoe
bigshoe
421
1,426
Yes it will starting a install on a 2021 later this evening it only says 16-19 p1000 and its the same
slicknik77
slicknik77
Minnesota
Thank you guys for all the input. I went with the warn winch mount. I appreciate all the help. Cheers 🍻
  • Love
Reactions: Montecresto
