Hello everyone. New to the forums here. I'd post to the "newcomers" area but they're still assembling my 2021 P700 at the dealership and it seemed like that would be anticlimactic to post there without a photo.
Anyway, I plan on using the P700 for plowing this winter in central/southern Maine and I was hoping to get some opinions on winch options for the plow. Of course there is potential for the winch to be used for recovery purposes, but I'm asking in particular about the utility while plowing. I guess I have the following questions I was hoping somebody may be able to shed some light on before I put an order in.
1. The main brands people seem to be going with are Warn, KFI, and Viper? Are there other brands I should be looking out for?
2. Is it worth it to spend the extra money on a KFI or a Warn winch vs a Viper? The salesman at the dealership noted that at that particular location, they were having better luck (read: shorter install times) with the KFI winch mounts vs the factory Honda mounts
3. Is it worth it to spend the few extra bucks on a 4,500 lb winch vs a 3,500 lb winch?
4. Is synthetic cable worth it?
5. It seemed like most plow setups come with either a lever setup or a pulley to reduce the severity of the load-angle on the winch, as well as a plow strap. Is there anything else I should be looking into for a plow setup?
Any input is greatly appreciated. I'm supposed to be loading the unit onto a trailer in about a week and a half and I was hoping to get everything ordered to be ready for then.
Thanks in advance!
Thanks in advance!
