P700 Winch or Tow?
JaLerz
JaLerz
40
31
NorCal
I have been told that the rear mount for the hitch is shaky at best. My questions is: If I am wanted to move some logs around the property, (nothing crazy, just ponderosa pine 10-15 feet in length, 18 inches in diamter) should I use my 4k KFI winch or a tow strap on the rear?
Thanks in advance for your input...
swsebek
swsebek
2,854
5,835
pa
Hitch is weak if pressure pushes up.
But for towing and down pressure you can pull anything that will move
BeerMonkey
BeerMonkey
455
1,515
Mid TN
Towing 100%. winch isnt really designed for all day work.
Not that you couldnt get away with using the winch just be mind full of the duty cycle
Russ989
Russ989
22,642
147,257
tow it, your fine. I made 4 piles @70' long x 10'wide and about 8' high of pines that I pulled like that.
Been awhile since I’ve seen that one, great video @ohanacreek.
Reactions: ohanacreek
JaLerz
JaLerz
40
31
NorCal
Thanks guys! Awesome advice as always.
Also now I can blame the liability on you guys so I can sue if anything goes wrong!
Hahahahhahahaha
alloutdoors
alloutdoors
1,022
2,184
US
  3. Do not currently own
A comment would be if towing try to hitch it in a way the nose/the leading edge close to the machine is off the ground an inch or so to avoid it digging in while pulling...
