Winch/Plow Install Headaches
chops
chops
Foster, WV
So I picked up my winch and plow yesterday. I started putting the plow together, and I noticed some discrepancy in the push tube instructions. Namely, the pulley assembly toward the rear. It instructions show a single pulley with a pin through it, but the only pulley that came with it was much smaller and in a bracket of its own. Anyone else run it this?
67,170
Could be why they have not posted the instructions on line yet!
chops
chops
Foster, WV
I think we got it figured out. Everything has been installed for a few days now. I'll try to remember to post some pictures later today.
chops
chops
Foster, WV
I promissed pics weeks ago. Sorry for the delay! Finally got around to taking some pics this evening.
Winch/Plow Mount
KS 4YVNy2 MN P3UDDbYkwjd7AFQifYyluQ8WJkwRAw269 h201 p no
IMG 20131225 174526
IMG 20131225 174518
Push Tubes/Plow
IMG 20131225 174645
IMG 20131225 174634
The Brainbuster (This is what was included with the push tubes, instead of the large pully that was pictured in the instructions from Warn.)
IMG 20131225 174601
IMG 20131225 174612
IMG 20131225 174552
One more of everything for good measure.
IMG 20131225 174656
After I got everything together I can see the design behind the odd piece, it would have just been nice if they would have documented it. The idea is that this piece can be "easily" removed to run the winch cable through, but it was a bit of an adventure to figure out how it went together.
67,170
Thanks chops. I do not have a use for a plow so I'll never really see one. But good to know how they mount on and all.
P
PioneerPapaw
14
14
N. Carolina
Will that type warn winch work?? That type is one I have and everytime you reverse direction you have to manually turn the knob on end?? Seems to me you'd need one that will work with up/down switch on dash......
67,170
Not sure your question.
Your kit should work with the winch in/out (or up/down) button. If not, something it wrong. You should not have to turn the red knob (free spool) on the end of the winch at all.
Neohio
Neohio
Beast of the East
17,765
85,684
Painesville Ohio
I would hazard a guess that he has a bad connection somewhere between his switch and contactor.
Like @Hondasxs said, there is absolutely no reason to have to free spool the winch to let line out. Bad connection somewhere.
Reactions: Mudwing and swsebek
