P1000m5 Winching techniques
Rackpioneer1000-5
Rackpioneer1000-5
9
19
Ross
I’m lookin at finally buying a winch. One thing I would like it to do is allow me to flip my pioneer over if I flip on the side. So my question is can a bumper mounted winch be used with snatch blocks to flip over from the side or would a hand help winch work better. Thanks for your input.
Reactions: swsebek and sharp
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Yep a bumper winch with a snatch block could definitely do the trick. That would be my preference...
Rackpioneer1000-5
Rackpioneer1000-5
9
19
Ross
Fe8c9113389bcab8bc570e4c5e81058d
So I would think I would need 2 snatch blocks right? Does this work flipping sxs over?
knuckledeep
knuckledeep
my trailer queen is trashy
1,052
3,470
Eustis florida
Either will work a bumper mount would be better just have a couple tree savers a snatch block a couple shackles
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Yep that would do it! Like mentioned above keep a couple of tree savers and shackles. Also go ahead and get you an extra winch cable for a spare. If you haven't already switch over to synthetic rope.
Reactions: knuckledeep
Rackpioneer1000-5
Rackpioneer1000-5
9
19
Ross
0ca2eb9305315629364740c20c677eee
Thanks guys. This is the winch I’m looking at. Defiantly going with the synthetic rope.
knuckledeep
knuckledeep
1,052
3,470
Eustis florida
Do what you want i would say get a bigger winch I have a 5k better to have bigger i have a tractor supply wiinch been awsome and seem to use it alot
Remember the 3500lb rating is on the first layer if you’re on layer 4-5 you may only get 1000lbs of pull from a 4500lb.
