To all,
Went to install my two piece hardcoat today and found out about a error in manufacturing and/or set up. If you purchase one of these kits, the lower windscreen mounts to the bracket that your window net clamps onto. My 2 was delivered with this bracket installed on the INSIDE of the cage/frame. THIS IS A WRONG INSTALL! You will need to disassemble to bracket and move the bracket to the OUTSIDE of the frame. I contacted my dealership and they informed me that two other Pioneers were delivered that way. This lower windshield will buckle due to excessive pressure to try and force it into place.
Once I installed the brackets on the outside of the frame, everything went in quite well- other than a plastic slide came cracked from the factory.
Good Luck!
Good Luck!
