L
Easy, because I ran a clear tube under the hood. Take a look at the picture. I use a funnel. Works great!I like where you mounted the fluid tank, how easy is it to fill?
What tank did you use? I noticed it but doesn’t look like a big tube, lol.Easy, because I ran a clear tube under the hood. Take a look at the picture. I use a funnel. Works great!
wadoy 12V Universal Car Windshield Washer Pump System with Jet Button Switch 160186 Reservoir Tank Bottle Kit https://www.amazon.com/dp/B06Y131DQ7/?tag=sxsweb24-20What tank did you use? I noticed it but doesn’t look like a big tube, lol.
I just ordered mine. Thanks for idea and info.wadoy 12V Universal Car Windshield Washer Pump System with Jet Button Switch 160186 Reservoir Tank Bottle Kit https://www.amazon.com/dp/B06Y131DQ7/?tag=sxsweb24-20
Be careful with the Nozzle install, I ended up hitting the windshield and cracking it. Washer works great though. I live in Minnesota and bought the winter mix (washer fluid )and it works great in the snow!I just ordered mine. Thanks for idea and info.
Ok thanks. My windshield appears a bit different with 3" metal surrounding it. Guess that's where nozzle will go. I'M in Wisconsin summer and Arizona winters, and yes can be useful both places. Btw, I bought the two position wiper/washer switch also from Amazon to replace existing wiper single position there now.Be careful with the Nozzle install, I ended up hitting the windshield and cracking it. Washer works great though. I live in Minnesota and bought the winter mix (washer fluid )and it works great in the snow!
I’ll be interested to see pictures when your done! Used mine today, I wish there was two wipers or at least the wiper was all the way in front of the driver.Ok thanks. My windshield appears a bit different with 3" metal surrounding it. Guess that's where nozzle will go. I'M in Wisconsin summer and Arizona winters, and yes can be useful both places. Btw, I bought the two position wiper/washer switch also from Amazon to replace existing wiper single position there now.
Just got done installing a washer pump and tank! Red button is for the washer. Plastics tube is for filling.
View attachment 240761 View attachment 240762 View attachment 240763 View attachment 240764 View attachment 240765
Looks great and no crack in the windshield like mine😁It's a done deal. Thanks for the idea. I did order from Amazon a wiper 2 way switch, but couldn't use it because my existing wiper switch is wired for "wiper return to home" which requires a much more elaborate switching system. I also needed to extend sprayer to clear windows gasket. Also didn't have much choice where to mount reservoir because my machine has an extra panel there for some reason.
View attachment 249214 View attachment 249215 View attachment 249216 View attachment 249217 View attachment 249218
Oh yes, I would think motorwouldhaveenough pressure. It is supplied with maybe 6 feet of hose. Not positive on the length, but I had 3 feet leftover. Btw it's designed for two sprayers. I only used one as only have one wiper.
