I
I have finally got all of my switches and radio wired in. I just cut the slots into the plastic dash. I figure if it breaks ill just make a piece to fit over the whole thing.
I used a switch to a relay to power the usb, rear lights, and horn switches and a seperate switch for the radio instead of using keyed on power. I originally had just the radio to turn on from the keyed on power and found out the fuel pump or something must run constant when the key is on. When I went to start it after it sitting for 10-15 minutes with the key on and radio on, it didn't want to start like it was flooded. I could smell fuel so that's why i'm assuming the fuel pump was running.
I got the Boss Audio Speakers off amazon as "used" $25 dollars cheaper just because the package is slightly damaged. I always go that route if its available.
