P1000m5 Wiring an Warn Axon
Seadonist
Seadonist
380
1,117
New Orleans
Hooking up my Warn Axon 45s and have a question regarding power hookup. My house battery is the OEM battery and I’ve got an Antigravity lithium battery for my auxiliary, connected by the True dual lithium system. I ran the rocket switch power to my Blue Seas fuse panel, which is run off of my lithium battery. Other than that, the only other cables needed for the Axon series is the power and the ground, which run direct to the power source. My question, more like confirmation request, is whether I should run the the winch off of my auxiliary battery. I assume that this is the proper way to run it. Thanks
Reactions: WagginTail
WagginTail
WagginTail
1,641
6,023
SC
Yes. Run it off the aux battery. That's how mine is
5,715
26,179
Yep, off the aux battery. Your goal is to protect the starting battery when you have to use the winch 'hard'. I had to use my winch, trying to pull another guy out, before I had the aux battery installed and was afraid to turn the buggy off because I ran the winch so hard.
