P1000 Wiring for chemical sprayer
BigOL3
BigOL3
2,994
8,920
My tow-behind spray rig has a 5.5gpm 12V pump with 20amp fuse. I had a long 14ga. wiring harness going from the battery temporarily, but had problem with it heating up and melting connections. Thought about having a shorter wiring setup coming from the 'cig lighter' plug, but was wondering how many amps it is set up to carry. If enough, I was going to use 10ga AWG wire to run back to the pump, that has a 12ga connection. Anyone know the wiring size to accessory plug or the amp capacity?
Gonna have to add a secondary circuit they’re too much for the lighter outlet. I did and use it as an auction for any 12v need.
Vikes79
Vikes79
SKOL!
11,709
113,613
South Dakota
  2. Talon X4 LV
I’ve been using the cig adapter for some time on a 60 gallon sprayer I have. Pretty sure the pump is around 5 gpm. Never popped a fuse either. Wire is never warm either.
It’s better to go direct with a fused 2 wire hookup and switch however.
BigOL3
BigOL3
2,994
8,920
I was hoping to avoid the situation I already had, which was having a temporary wire running from under the hood to the rear, by using the lighter outlet.
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I run mine off the cig but its only like 1.5 gpm. I'd say put in a switch and run 12ga wire to the back of the machine and have a little SAE plug you can plug in to when the sprayer is on.
BigOL3
BigOL3
2,994
8,920
Probably will have to. I just hate running another set of wires to the back, but probably will be the best in the long run.
Reactions: Vikes79
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
Yea but you can always use it for other stuff too like extra lights or something 🤷‍♂️
Reactions: BigOL3
208,726
Go buy one of those small Honda generators and mount it to your sprayer?
  • Haha
Reactions: BigOL3
Go
Go ahead and run extra... ps, I like using 12g outdoor extension cords. You’ve got 3 wires in one shielded bundle.
jacket will come off after time unless you use quality cord “SOOW” rated would be where I’d start.
Never really thought about using an ext. cord. Reckon, those mate/female couplings could be used when applied to 12V?
Absolutely could.. I usually just cut them off and use the independent wires I’ll either run 2 cords so I have a total of 6 wires 3 hot and 3 grounds so I don’t have to ground to the cage or frame, that way I usually don’t have any wiring issues later down the road from bad grounds.
Reactions: Mudwing and BigOL3
CargoCaptain
Bardstown, KY
I use a deep cycle battery to power my 3.8 gallon per minute sprayer. Place the battery near the sprayer. I can spray for hours before recharging the battery.
208,726
I just love simplicity! Totally makes since!
60,382
This is what my father does as well. Buy a good battery and a $20 tender from HF and don't worry about running any wires
60,382
He sprays 25+ acres at a time, just put the battery on the tender after you spray. He uses the same battery for trailer winch or any of the other 12v applications where he only uses it sporadically
Reactions: JTW
Russ989
Russ989
22,642
147,257
Why not just get an extra battery for it and save the trouble of having to wire it in? I like everything being able to connect to the pioneer but I I weren’t using it a lot, that’s what I’d do. A couple alligator clips, a battery and ride off into the sunset. 😉
BigOL3
BigOL3
2,994
8,920
I already have the 2nd battery under the hood. As for a 3rd battery laying in the back, not to crazy about that idea. I need to spray at the camp in MO Ozarks. Up and down rough hills, the battery would be bouncing loose in the back.
Reactions: Russ989
Russ989
Russ989
22,642
147,257
Yeah, for that application, my idea isn’t going to do you any good.
Reactions: BigOL3
