P1000 Wiring Gurus..advice needed
Plante11
Plante11
45
110
Maine
Calling all wiring Gurus. I’m currently in the process of adding some electronics. Among them are a dual battery set up, relay/fuse box, and switch plate.
I was just wondering how badly I butchered this wiring schematic!?
  • RELAY BOX.pdf
  • SWITCH PANEL.pdf
66,870
I don't see any issues. This is how I run most of mine but with a different system.
Something to think about.
Consider freeing up a relay to provide power to the panel. If you do this, then you can skip installing a larger relay like a stinger.
A DPDT switch can then be used to power the panel relay and provide you both key-on use and key-off usage. Key-off will be a constant so it will need its own 5a inlne fuse. Key-on will already be fused through the factory ACC fuse if wired as such.
Also an idea.
For low draw items, (Ex. dome light, winch, radio trigger) you can use 1 relay to power multiple things thus allowing you to expand the panel but not expand the relay board.
It will require an additional wire to each switch for source power that can be jumped to just those low draw items.
Reactions: TripleB and Mudwing
Plante11
Plante11
45
110
Maine
Thank you for the reply, @Hondasxs. I’m new to circuits and spent hours researching all this recently!
You mention freeing up a relay for a switch to power the panel. I intend on installing a breaker and having this powered entirely off the AUX battery and using a tap on the ACC power cable to power my switch panel so they would be key on.
Would that be an alternative to what you mentioned, or in addition.
Another question I had was about using 1 relay for multiple switches. Like having my my dome lights, rear lights and Rock lights on the same relay. Is that possible or a bad idea
nitzo
nitzo
521
1,105
East Coast, Florida
One thing I would highly consider looking at is this. Feniex 4200
Fenex
Reactions: JenElio
66,870
Yes, what I mentioned is an alternative to a complete key-on system.
1 relay-- 3 accessories.
That is what I was mentioning. the relay would come on with key-on. It would then feed the switchs @#2. You can jump it to all 3 switches. Then feed the accessory. So full power would be passed through the switch. You will need to account for your AMP load keeping the combined accessories load under 10 (20 max) amps or so. Downside is... If one shorts you lose them all unless you fuse each one.
There is a dozen ways to do it.
