L
I’ve been doing several things to the machine here lately. Added front led light, rear led light, added winch. Been doing quite a bit of wiring and have added second battery. I’ve got one question that I would like opinions on. I had power directly to my winch solenoid and then came off and went straight to 80 amp stinger. And then had switched power to my fuse panel. The more I looked at this, I just didn’t like it. I had to run 2 wires off same positive terminal on winch solenoid to make this work. Tonight, I moved my winch power to the switched side of my 80 amp stinger. Now when I switch my main rocker switch on my switch panel it activates my stinger and sends power to winch and fuse panel. I like this better but will it be okay like this? Disregard my factory battery being out, I bought an amazon wireless winch relay to put it in and had factory battery out. (It was bad out of the box by the way) Thanks in advance.
