P500 wiring question
luckymike
luckymike
144
322
michigan
i installed a superwinch that has a solenoid.i recently purchased a Micro-Start jump start from antigravity batteries.bought it with a lead that can be attached to battery so i can just plug the jump starter in and not deal with the clamps.can this fused lead be attached to my winch solenoid instead which is mounted under my hood.thanks
273,263
It would be best to attach directly to battery terminals.
67,170
Hello,
This would not be considered the correct method. But yes, it will work to charge your battery in time of need.
Reactions: ohanacreek
Hello,
If you have 4 or 6 gauge wire it shouldn't matter as long as the winch is connected direct to battery on + & -
Frame ground isn't as good for this purpose.
As @Hondasxs said it's not ideal but it will work considering it's large gauge wire.
luckymike
luckymike
144
322
michigan
thanks for the quick replies.I'll hook it to the battery and just tuck the plug up and out of the way.thanks again
