P1000m5 Wiring questions
Cohutta
32
29
NWGA
I'm a DC wiring novice. I'm adding lights and a 2m ham radio to my P1k5. I have the aux battery and isolator installed and functioning properly. I have a wiring harness on the way with 5 relays on it. I have those relays planned for 1)front lights, 2)side lights, 3)rear lights, 4)interior lights, 5)fan under seat. It also has 10 fuses, one of which will go to the radio.
Questions:
- If I tap the brown "power on" wire for rocker switch lights, do I need a relay?
- If I add rear back-up lights(in addition to switched rear lights) and tap the back-up alarm wire, do I need a relay?
All lights are 18w LED, except the interior red LED. I'm not sure on its power.
Another question. Do you see a problem with mounting the radio bracket to the roof? I thought about under the driver's seat with a remote faceplate, but then realized I might end up in water.
ghost
ghost
993
1,874
BC
I like to keep my electrical isolated as much as possible from factory wiring. I use a switch and solenoid to power my aux systems.
--> Not required but mine would be if I used it. Mine connect thru the aux solenoid and fused when the switch in on.
--> Not required but mine are. Since backup lights are ground triggered you probably need a different relay - your harness is probably + triggered
I think you're one the right track keeping anything that touches factory wiring powered thru relays. The only factory wiring I touch are:
- dual battery setup via isolator
- rear backup light via relay
Some - if not all of your relayed circuits (interior light, fan etc) could be run on fused lines if you want. Saving the relays for the heaviest power users.
I'm planning to change to a three way switch for my custom systems.
Switch down - Custom systems activated by key-on power.
Switch middle - Custom system off
Switch up - Custom systems on. I'll add a warning light somewhere to remind me its on.
I'll keep everything on via key-on power most of the time but have the option to switch it to always-on so I can run stuff with the machine off.
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
What he said lol. Hey I can answer the roof question lol. If it's a factory roof, there's no problem with mounting radio bracket on it. That thing is next to indestructible. I have my light bar mounted to mine. It's tough as they come.
Cohutta
32
29
NWGA
Equipment:
- Odyssey PC925L battery
- True Dual Batt Isolator and Monitor Amazon.com: True UTV-SBI-15CM UTV Dual Battery Connect & Monitor Kit: Automotive
- Cooper Bussman relay/fuse box, positive switched Universal Relay/ fuse auxiliary distribution box jeep, Cooper Bussmann Off Road
I have the Odyssey and isolator installed, but no voltmeters. I'll install them when I install switches.
The plan is to be able to run the lights and radio with the switch off. OK plan?
Ghost, what is the purpose of the second solenoid and how is it wired? Is it switched with the ignition?
What type of relay and harness would I be looking for to run the back-up lights? Do I run a hot wire all the way to the battery? Same for the switch LED's.
