P1000 Wiring through the roll cage
Jcouch_84
Arkansas
I'm getting ready to wire up some lights &a other stuff and would like to hide the wires as much as possible. Anyone know which parts of the roll cage are hollow and where it's not? I'm thinking of mounting a light bar up top in the middle of the roll cage.
You should be able to tell.. I tried running wires thru the roll bars on my last pioneer.. it didn't workout so well for me. Good luck.
322,675
It's easiest to come up the back bars. The front isn't too bad but that first bolt point a few inches up has to be avoided and wire tucked back sharply to the side of the dash and isn't appealing. The rear all that shows is a little coming out of the frame to the ROPS. Center is a no go.
115,818
@CumminsPusher is correct and summed it up well. As for me, I tried and got flustered like a wet Saint Bernard trying to get through a cat door and avoided it like the plague, and just got some good thick coated black wire and nicely tracked it along the roll cage with zip ties. If your not looking for it, you won't notice it. Good luck with witch ever one you decide to do
