P1000m5 WTB Roof Mount Brackets
Traderquinn
7
10
Lee's Summit, Missouri
I can't seem to find roof mount brackets anywhere for my P1000-5.
Mine are rusted out from saltwater.
20211029 221146 20211029 221152 20211029 221237 20211029 221306
107,104
Looks like the ROPS is rusting out as well!
try an alien shade and ditch the roof Or make some out of aluminum.
bumperm
bumperm
1,851
6,653
Gardnerville, NV
Not gonna ask you how you got salt water up and in there. Ah what the heck, how'd you get salt water up there?!
It may be possible to save the brackets if they are still mechanically strong. Phosphoric acid will change the rust from ferrous oxide (rust), to ferric phosphate. Dilute phosphoric acid (called rust converter etc) is available at most hardware stores. It is also called metal prep and is used to acid etch aluminum prior to painting.
Traderquinn
7
10
Too much rust to save them. I bought the rig from an agency that used it as a beach patrol vehicle, so it spent all day splattering salt water up all over. I know, sad.
I'm replacing the entire frame, and most of the hardware in it. I just can't source the roof mounting brackets anywhere.
107,104
Aluminum would be ideal. I don't have the time or know-how to do it myself. I'd rather order something that fits just right. Can't seem to find a source.
Just go to the hardware and buy some aluminum flat stock. If u have a vise or even channel locks you can bend it easily. Take the bracket‘s off u have, take your time and mimic the design. Good time to learn! There a first time for everything ;)
